Old 08-27-2008, 07:02 AM   #1 (permalink)
saintload's Avatar
Manual driving with Neutral
Since this car uses a standard clutch, would it be ok to slip the car in Neutral when going down a hill and putting it back in Drive/Manual once the car started to either slow down on a flat surface or when going back up a hill?
I missed doing that in my manual transmission car.
Short Answer:
Don't put it in Neutral to coast, leave it in gear.
saintload is offline   Reply With Quote
Old 08-27-2008, 07:04 AM   #2 (permalink)
saintload's Avatar
Nevermind, found the post with someone asking the same thing. Couldent find it when I was searching but I got it now. OK to coast downhill in Neutral?
Old 08-27-2008, 12:58 PM   #3 (permalink)
I haven`t read the other post - but to answer your question - no it is not OK. With modern fuel injected engines controlled by computer, you actually get better gas mileage by leaving the transmission in gear while coasting. This cuts off all fuel delivery to the cylinders. If you shift to neutral the engine will be supplied enough fuel to idle the engine. Another factor to consider is that in neutral there will be no engine braking. Also, you will be putting yourself in a position of not being in full control of the vehicle. Only place a transmission in neutral when the vehicle is stopped.
Old 08-27-2008, 01:27 PM   #4 (permalink)
I am in the Jungle baby!
smartHHO's Avatar
Drive: 2009 Rally Red Cabrio
I tried both coasting and with neutral while stopped. Improved 4mp on my kia.
I try just stopped next time and see if that is where I get the milage. I probably would not do it on the smart though. Esp when it gets that good of MPG.
Old 08-27-2008, 01:30 PM   #5 (permalink)
saintload's Avatar
The post that I found goes into great depth with answering my question. Thanks for your responses.
Driving a smart is like driving...? theguywiththelongestname Off-Topic Cafe 55 11-02-2009 02:32 PM
OK to coast downhill in Neutral? hampyoung Smart Car General Discussion 78 11-02-2009 10:20 AM
451 Full Manual & Quick Manual (US Version) rrrucke Smart Car Operation and Maintenance 28 02-26-2009 03:08 PM
electric-auto manual or manual with clutch pedal, your favorite? mr_Cash Smart Car General Discussion 47 02-19-2008 10:05 AM
451 Service Manual Available? oldbike Smart Car Operation and Maintenance 1 01-30-2008 10:28 AM
