Originally Posted by jwight
I'm sure the "high performance" of the 70 hp engine is what precluded use of a MAF in the smart, although it doesn't seem to affect the 430 hp LS3 Vette engines much.
No I agree that it doesn't affect the vette engine much but it does affect it to some degree as the MAF has an actual air sampling sensor inside the intake tube. The benefit is that you have something a lot more accurate compared to "guessing" but the con of that is the sensor itself does take up space inside the intake tube. On the flip side, as technology gets better and with enough info, "guessing" the amount of air going into the engine gives the same result as an ECU that has the MAF sensor but without anything disturbing the air flow.
Some MAF sensor are pretty restrictive and some are not. Just like regular factory CAT and aftermarket high flow catalyst converters. They all have their pro and con's..... as you point out.. to various degrees ;)
Personally I would choose to have a MAF =P... from what I recall it's just a wire or two that senses how much air is flowing pass it by how much the wire is being cooled down.
Cheers!
Larry
