Max speed per gear in manual mode? - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 08-22-2008, 07:20 AM   #11 (permalink)
saintload's Avatar
I knew someone else would find this helpful as well. I dont have a tach yet either.
saintload is offline   Reply With Quote
Old 08-22-2008, 08:00 AM   #12 (permalink)
saintload's Avatar
Im going to add to the thread all the information so people dont have to go searching for the answer.
Old 08-22-2008, 11:40 PM   #13 (permalink)
My new 2008 Passion is just being broken in now. It does have the tach but during break-in I don't want to push it too hard. Do I understand that there is no rev limiter such as fuel or ignition cutoff but that the computer will upshift at a specific rpm of it's own accord despite the driver wanting to keep it in a lower gear?
If that is indeed the situation it then that is actually a different method of rev-limiting.
As to what speed you should shift at - that is a function of engine revs, not road speed - but naturally gearing would determine the roadspeed at any given engine rpm. If you don't have a tach, and the computer will force a shift to protect the engine, then why be concerned about it at all?
The only thing to be very careful about is to avoid downshifting into a gear that would overrev the engine - I presume that the computer would allow a driver to do that.
Old 08-23-2008, 06:21 AM   #14 (permalink)
SylenThunder's Avatar
Originally Posted by saintload View Post
I
Gear 4 Max speed: Not enough HP to reach.
Gear 5 Max speed: Not enough HP to reach.
It's not that there's not enough HP... it's the speed governor that keeps you from going faster than 90mph.
Old 08-24-2008, 03:41 PM   #15 (permalink)
I know that our Cabrio will easily go to the engine cut-off speed, which on ours is just over 90 MPH indicated in 5th gear. No problem having enough power to get there.
The ECU should keep the engine from over-revving in any case. If you choose a downshift and the computer determines that the speed is too great to do the downshift without exceeding the programmed limit, then it will delay the shift? I've been told that, but not tried it myself cuz I'm a bit of a sissy...
These little cars actually shift and drive very nicely in a " spirited " way. I like the way the car drives far better in " the twisties " than in the city to tell the truth. I've run up on the ESP limits a couple times and it feels a bit strange but nothing all that goofy. The car has a bit of understeer which is to be expected on standard tires up front, but instead of transitioning to " terminal oversteer " like a " proper " rear engine car.... the ESP " saves " the day for me. How thoughtful.
I'd actually like to disengage that ESP and let it all hang out maybe now and then and spin like a top, the way a " proper " car ought. I guess I'm too old for that sort of thing these days and somehow the Cabrio has sensed it. How " smart " is THAT ?
Old 08-24-2008, 10:40 PM   #16 (permalink)
saronian's Avatar
In manual mode, at what speed will the computer take over and shift into the next gear?
From Road & Track Magazine March 2008
Top speed in each gear
Gear 1 Max speed: 28 Mph 6500 Rpm
Gear 2 Max speed: 49 Mph 6500 Rpm
Gear 3 Max speed: 74 Mph 6500 Rpm
Gear 4 Max speed: 90 Mph 6000 Rpm (Electronically Limited)
Gear 5 Max speed: 90 Mph 4500 Rpm (Electronically Limited)
Old 08-25-2008, 12:50 AM   #17 (permalink)
mendo's Avatar
Originally Posted by EpicSmartHere View Post
Thanks Wiz and Mendo.... This is some really good info. I don't have a tach yet and was worried when in forth on the freeway (changing lanes at 65-70 mph) about redlining.
I refuse to use automode
Not gonna worry anymore.
if you use manual and stand on it the system will not let you overrev above 6500. In my experience, this driving style SUCKS THE FUEL RIGHT DOWN!!!!!. just so you know,
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/max-speed-per-gear-manual-mode-12901/
Smart Car Blog: Smart Car Accessories This thread Refback 08-21-2008 01:30 PM
Shifting between Auto mode and Manual mode jthomas119 smart Operation and Maintenance 2 02-27-2008 11:05 AM
electric-auto manual or manual with clutch pedal, your favorite? mr_Cash smart General Discussion 47 02-19-2008 10:05 AM
Shifter labeling for manual mode...needs update/change young-nyc smart General Discussion 17 01-27-2008 04:22 PM
Observations on the manual mode.... kags1969 smart General Discussion 2 01-26-2008 08:38 AM
Single Speed/ Fixed Gear Road Bike Rogue Smart Off-Topic Cafe 2 12-06-2007 10:19 PM
