Mirrors Vibrating - Smart Car of America Forums : Smart Car Forum
Old 06-23-2008, 12:30 PM   #1 (permalink)
Never Stop!
Carl242's Avatar
Mirrors Vibrating
So right since I got my car, there has been a major buzzing sound at certain RPM's (and certain frequencies after I put my sub in). When I say major, I mean really loud, and very abrasive. When I got a check engine light after the 1st 150 miles, I noted that to the dealer as I dropped the car off. They fixed the engine light, but they did not fix the buzzing.
After a while, I was able to actually locate the buzzing . . . its coming from my rear view mirror! If I hear the buzzing, and I push the lever on the mirror or squeeze the top and bottom of the mirror, the buzzing goes away. 10 minutes later, however, the buzzing will come back as whatever it is inside the mirror goes back into place.
Moreover, when I "silence" the rearview mirror, another, less audible buzzing makes itself apparent. I was able to localize this to the passenger vanity mirror buzzing against the roof, when the visor is up.
Does anyone else experience this? Do you think that I have a good case for the dealer to fix this under a warranty? In a brand new car I shouldn't have to deal with it sounding like 10 year old car that has been on one too many dirt roads
Carl242 is offline   Reply With Quote
Old 06-23-2008, 12:32 PM   #2 (permalink)
eqwalker's Avatar
I don't think you will have much luck getting the dealer to fix them. May have to try some home remedies. jmo
Old 06-23-2008, 12:41 PM   #3 (permalink)
Smart Enuf's Avatar
There's already an extensive thread on this issue:
Driver mirror shakes
Some suggestions in there might help you.
Old 06-23-2008, 12:41 PM   #4 (permalink)
bull8042's Avatar
Your mirror/s are not the source of the noise, but rather where the noise is manifesting itself. I think it might be something along the lines of a wheel bearing or the like creating a vibration that is not necessarily bad enough to feel in the seat of your pants, but can cause a noise like the one that you are experiencing.
Old 06-23-2008, 12:45 PM   #5 (permalink)
Smart Enuf's Avatar
Good point. Fixing the mirror vibration may only hide a bigger problem.
Old 06-25-2008, 03:47 PM   #6 (permalink)
Take your car and have all the wheels checked for balance. Unbalanced tires will create this type of problem. Question is the noise while you are moving or just setting in the car with it running or the sound system very loud ???????
JIM VINYARD is offline   Reply With Quote
Old 06-25-2008, 03:50 PM   #7 (permalink)
Never Stop!
Carl242's Avatar
Either with the sound loud or going over certain types of road surfices or bumps. I can easily repeat it by driving over the lane markers on the freeway.
Old 06-25-2008, 06:27 PM   #8 (permalink)
FWOIII's Avatar
My drivers side mirror vibrates....checked antenna, had wheels rebalanced, tried weights on the back side or mirror. Still does it, but the passenger one is fine. Any more ideas?
FWOIII is offline   Reply With Quote
Old 06-25-2008, 07:07 PM   #9 (permalink)
Smart Enuf's Avatar
Have you tried actually removing the mirror and then tightening every bolt back on? Here's a guide for removing them:
http://www.fq101.co.uk/451mirrors.asp
Old 06-25-2008, 07:43 PM   #10 (permalink)
FWOIII's Avatar
Yes...the smart tech has twice.
buzzing, mirror, rattle, sound
smart signal mirrors might make sense Carnut Interior & Exterior 9 05-16-2008 11:47 AM
Vibrating Drivers Side Mirror FWOIII smart Operation and Maintenance 9 05-05-2008 10:57 PM
Blind spots, mirrors size. Learn2relax smart General Discussion 52 04-21-2008 07:18 PM
Manual Windows, Sideview Mirrors & Grey Interior smartdabbler smart fortwo (451 - US vehicle) 5 03-09-2008 08:13 PM
