Is neccesary to replace the brake fluid at 20k? - Smart Car of America Forums : Smart Car Forum
Old 06-15-2009, 07:34 PM   #1 (permalink)
Or you can change it when you change the brake pads?
Old 06-15-2009, 07:41 PM   #2 (permalink)
smartune's Avatar
Check it and see what color it is, any darker than amber and it should probably get changed.
Best,
-Dan
Old 06-15-2009, 08:20 PM   #3 (permalink)
Godfather's Avatar
How are the techs at the smart centers going to be able to send their kids to college if you don't follow the factory service schedule?
Old 06-15-2009, 08:22 PM   #4 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...does the factory brake fluid has an aroma like the washer fluid?...
jetfuel...in Uvalde Tx
Old 06-15-2009, 09:35 PM   #5 (permalink)
SmartDigger's Avatar
Imho no.
Old 07-09-2009, 10:13 PM   #6 (permalink)
Smart_Dude's Avatar
Mercedes recommends (for what seems like decades) changing brake fluid every 2 years; regardless of the mileage driven. This makes more sense knowing that brake fluid is extremely hydrophilic over time (versus mileage), which means it absorbs water very easily. The absorption of water, unfortunately, reduces the hydraulic capability of brake fluid.
In a quasi-sealed brake fluid system, air (which does contain varying levels of moisture) ‘contaminates’ the brake fluid. Over the course of 2 years, most brake systems have absorbed enough water vapor to change the hydraulic characteristics of the fluid a significant and perceivable amount. Whether your car is stationary or driving 30,000 miles a year, the brake fluid is absorbing moisture through the tiny brake fluid cap vent port. I know it sounds crazy, but true.
I am pretty anal about changing the brake fluid in my Mercedes every 2 years, and I do sense a stiffer brake pedal after each fluid change; not as ‘spongy’ or weak. Can you change it more often? Of course, but I do not find it necessary. Smart seems to have crafted their periodic maintenance on a mileage schedule, while Mercedes uses both mileage and time duration. I haven't owned my Smart cars long enough to reach the 2 year mark, so my experience is only on Mercedes.
Cheers,
Jeff
Smart_Dude is offline   Reply With Quote
Old 07-10-2009, 09:48 AM   #7 (permalink)
GHammerly's Avatar
Every two years religiously. Will keep corrosion away and increase the boiling point of your fluid. Also good for the ABS pump and valve body.
I like the Valvoline synthetic stuff but any DOT-4 will be fine as long as you replace it once in a while.
Old 07-10-2009, 10:57 AM   #8 (permalink)
Interesting article: http://www.brakestrips.net/docs/indu...guidelines.pdf
Also an indication that Mercedes may be switching or have switched to a 10K mile brake fluid change requirement: Brake fluid change frequency - Benzworld.org - Mercedes-Benz Discussion Forum
Old 07-10-2009, 03:26 PM   #9 (permalink)
Godfather's Avatar
Jeez, what next, 3000 mile oil changes? LOL
Old 07-10-2009, 03:28 PM   #10 (permalink)
Depends: is the oil you use hygroscopic?
What this car needs is.... (a windshield washer fluid indicator) jetfuel smart Modifications 45 02-18-2010 11:58 PM
Factory Washer Fluid magilly00 smart Operation and Maintenance 26 12-16-2009 08:51 AM
Best transmission (oil) for 451? torqueaholic smart Operation and Maintenance 62 10-25-2009 02:39 PM
Transmission Fluid for Smart Marco smart Operation and Maintenance 13 06-03-2009 03:10 PM
Anyone purchased smart transmission fluid? Padawan smart Operation and Maintenance 26 04-04-2009 08:31 PM
