No oil drain plug in earlier SC's?? - Smart Car of America Forums : Smart Car Forum
Old 01-26-2008, 07:25 PM   #1 (permalink)
doc540's Avatar
http://cgi.ebay.com/ebaymotors/MCC-S...em320210253639
Ok, what am I missing here?
Don't tell me they had to SIPHON or drop the pan to change the oil in '98-'07 engines.
doc540 is offline   Reply With Quote
Old 01-26-2008, 07:50 PM   #2 (permalink)
My understanding is that they sucked it out of the dipstick tube with a electric pump. Too strange!
Old 01-26-2008, 08:06 PM   #3 (permalink)
Correct; the eBay thing is a modified pan with magnetic drain plug, 450s only. There's a previous thread in the 450 section.
Old 01-26-2008, 08:42 PM   #4 (permalink)
Dont Feed The Trolls ^Mod
jediknight36's Avatar
Even tho it seems odd, mobile oil change services exist where they suck it out thru the top.
Old 01-27-2008, 03:55 AM   #5 (permalink)
It is very common for marine engines to be installed such that the oil pan drain plug is inaccessible and/or there is insufficient space in the engine bilge to fit a catch pan. Therefore, pulling the oil out via the dipstick tube is common practice, and the marine supply houses carry a number of different types or oil change pumps. Mine is simply a plastic jerry with a vacuum pump - once the jerry is evacuated (about 20 strokes) you push its hose down the dipstick tube to the bottom of the pan, release its pinch-clamp, and sit back and wait for the (pre-warmed) oil to come out. It is actually less of a bother than crawling around on your back with oil running down your arm.
http://www.westmarine.com/webapp/wcs...&storeId=10001
Old 01-27-2008, 12:46 PM   #6 (permalink)
Old SGM's Avatar
Sounds like another way to keep you coming back to the dealer for service. For me adding an oil drain plug will be my first modification, even if I have to remove the oil pan and have a drain bung welded in. Is the oil pan metal?
Old 01-27-2008, 12:56 PM   #7 (permalink)
Gortok's Avatar
Originally Posted by Old SGM View Post
For me adding an oil drain plug will be my first modification...
Whoa there, buddy!!
You don't need any mods here. The new ones come with a plug...
Old 01-27-2008, 01:02 PM   #8 (permalink)
Old SGM's Avatar
Since I have to wait till around July for mine, I didn't know that.
One less mod.....
Thanks for the info.
I am a hard core tinker'er. I'll find something to improve on or upgrade.
Oil pan w/drain hole and magnetic drain plug jwight Original (450) smart fortwo 11 12-18-2007 10:27 AM
Volvo Unveils A Plug-In Hybrid SMART The Car Lounge 3 09-21-2007 07:04 PM
