Noise from Speakers Key Off - Smart Car of America Forums : Smart Car Forum
Old 09-13-2009, 12:34 PM   #1 (permalink)
We had a popping noise coming from the speakers when the ignition switch is off. Removed number 15 fuse (15amp fuse) to radio. That stopped the noise. Using radio controls did not help.
Is there a relay that should open when the car off and the key out?
Where is it located? A wiring diagram or schematic would be helpful
TIA
George
GeoCar is offline   Reply With Quote
Old 09-13-2009, 12:51 PM   #2 (permalink)
Carlarm's Avatar
It sounds to me like your radio is defective. If your car is still under warranty I suggest you take it to your dealer and have them troubleshoot the problem. The radio is not totally off even when you remove the key. Note that you can turn it "on" without the key.
Old 09-13-2009, 12:59 PM   #3 (permalink)
Thanks We are to take it in this week now all we have to do is include the problem.
Old 09-13-2009, 08:18 PM   #4 (permalink)
fastturb's Avatar
in both of my 2009 smarts the radio works fine (long time) with out any key on or in ignition. just push the ON button!!
Old 09-13-2009, 08:31 PM   #5 (permalink)
Owner for 3.8 years
Kermit's Avatar
SOMEWHERE on this site someone had THE SAME EXACT problem. I'm not a search expert so I can't be much of a help but someone here had the problem before. Hope you can find the answer, it is there.
Old 09-13-2009, 09:01 PM   #6 (permalink)
Old 02-04-2011, 11:46 PM   #7 (permalink)
speakers popping
Very hot humid day. Speakers popping when engine turned off. Followed what Geo Post did and removed 15 fuse and popping stopped. Will contact Smart dealer for advice but live 200 kilometres from dealership. Anyone else found a solution?
gwyns is offline   Reply With Quote
HELP~! Speakers popping noise . . . SubSlr88 smart General Discussion 5 10-17-2010 05:22 PM
Noise level mirando smart General Discussion 32 08-11-2009 04:25 PM
Fan noise? tovilin smart General Discussion 10 01-04-2009 09:02 PM
What are the best speakers to replace Radio 9 factory speakers with? mnext02 Audio & Video 17 05-20-2008 05:15 AM
Whining Noise lilsmart smart Operation and Maintenance 7 03-18-2008 02:22 PM
