Oil Change Question - Smart Car of America Forums : Smart Car Forum
Old 04-20-2009, 10:41 AM   #1 (permalink)
Oil Change Question
I changed the oil in my smarty this weekend but I mesread the owner's manual and didn't buy enough oil the first time out (bonehead move #1). I ran into the auto store this morning and, because I was in a rush, bought the same brand but wrong weight oil. (bonehead move #2)
Right now the car has 2 qts of Mobile 1 synthetic 0W - 40 and I bought 2 more qts of Mobile 1 synthetic 0W-30.
2 questions - (1) can I drive the car a short distance with only 2 qts in it?
If not (2) can I mix the oil (maybe end up with 0W-35?)
fmichael2 is offline   Reply With Quote
Old 04-20-2009, 10:45 AM   #2 (permalink)
MPrice2984's Avatar
Don't drive your car with 2 quarts in it. It will be OK to run the 0-W30 with the 0-W40. The oils will mix fine and the 30 weight is good to about 90 degees farenheit.
Old 04-20-2009, 12:52 PM   #3 (permalink)
NeWave's Avatar
Yeah, you'll just end up with a "thinner" 40 weight. Pretty well harmless.
Old 04-20-2009, 02:00 PM   #4 (permalink)
As the lead in says, more than you ever wanted to know: Vintage Triumph Register - VTR
Old 04-20-2009, 02:12 PM   #5 (permalink)
Be cautious of the American Petroleum Institute SG grade oils refered to in the VTR ("All of the oils above meet current SG/CD ratings and all vehicle manufacture's warranty requirements in the proper viscosity. All are "good enough", but those with the better numbers are icing on the cake."). SG oils became obsolete years ago; the current API grade for engines designed and built since 2004 is "SM."
Old 04-21-2009, 01:27 PM   #6 (permalink)
OIL CHANGE,at 1030,miles.
Just did it this morning.Got the info from Old Smart on filter.Gave NAPA the Misti. number and they had the one. Slightly bigger but not a problem.
Never figured out if they ship the car with reg. oil or mobil 1.But it didn't look synthetic.Anyways,used Penz. 5w30,probly 5/40 or 10 /40 next time.
Oil wrench too big,pipe wrench worked fine.Won't need that next time.Drain plug,didn't have large enough socket.Hammer and cresent wrench worked.Won't need that either agin.I know a cresent wrench near a car is a bad thing,it won't happen next time.
bob/cathy is offline   Reply With Quote
Old 04-21-2009, 01:45 PM   #7 (permalink)
Originally Posted by bob/cathy View Post
... Never figured out if they ship the car with reg. oil or mobil 1.But it didn't look synthetic. ...
smartUSA has let it slip that the engines come out of Japan with a non-synthetic engine oil, and is the reason that sUSA has been recently experimenting with an early change to synthetic oil at the U.S. vehicle processing centers (all getting Mobil 1 0W-40). sUSA doesn't want to wait until the first scheduled maintenance at 1yr/10K miles to change to synthetic.
When I asked the reason for the early change (wanting to get synthetic in for the sake of the engine, or wanting an early engine flush, or wanting to get Mobil 1 in to satisfy some contractual agreement) they stopped communicating. The experiment was/is to compare doing the change at the VPCs or in Japan before shipment of the engines to Hambach. Changing the oil at Hambach seems not to have been in consideration.
Also, no response was returned when asked if the Japanese fossil oil was intended to be a break-in oil for some period.
Old 04-21-2009, 01:49 PM   #8 (permalink)
by the way
That little filter in the drain plug?never saw that befor,what's it there for?If it is 'clean' than does it mean I didn't need to change the oil so soon? Still think if they ship the car with reg. oil and recommend 10,000 mile oil changes it may be a scam.Our 07, f150 has a BP sticker,Ethanol,but have never found a BP station that had ethanol.
Old 04-21-2009, 02:00 PM   #9 (permalink)
OLD OIL?
So if we want to conserve oil,a country that has no oil,ships its cars with old,'basic' oil,so you can get rid of it and conserve oil?
Old 04-21-2009, 02:17 PM   #10 (permalink)
Sort of off topic, but the assumption that "we" want to conserve oil may be faulty. As the manufacturers improve engine technology and the oil companies improve their oils to enable longer oil change intervals, old habits die hard - some folks can't let go of the 3K mile oil change, others want to do the "engine flush" thing, etc. Must really confuse the auto and oil company engineers.
act in haste, repent in leisure
First Oil Change -- Can this be right? Prospero smart Operation and Maintenance 38 10-14-2009 03:11 PM
first oil change question - should i get an adapter for regular filters? britboy smart General Discussion 9 12-04-2008 08:37 AM
Oil Change donaldej3733 smart General Discussion 31 12-01-2008 12:58 AM
Oil Change Ron F smart Operation and Maintenance 9 10-25-2008 04:29 PM
oil change SmartDigger smart Operation and Maintenance 9 04-11-2008 10:48 PM
