Oil Change Question - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 04-21-2009, 02:59 PM   #11 (permalink)
Jwight
Worked in a power station 25 years,never saw an engineer that needed any help in being confused. The point was,if you are going to get paid to 'engineer 'a car and expect the user to use Synthitic oil,why would you ship it with,'old' oil? Yes,it has to do with conservation.If every car produced hat pure synthetic,and recommended 10,000 miles changes,sell your stock in jiffy lube.
bob/cathy is offline   Reply With Quote
Old 04-21-2009, 03:17 PM   #12 (permalink)
Originally Posted by bob/cathy View Post
... why would you ship it with,'old' oil? ...
Modern API SM grade fossil oil isn't exactly "'old' oil." It is perfecty acceptable if used within its intended parameters - that its extreme ends of its viscosity range aren't challenged, and that it not used in extended oil change intervals (10K +). Many manufacturers still specify a 7,500 mile interval (in ideal, non-severe service use), and a fossil SM can do that.
We don't know what Mitsu's intended interval is; M-B won't pass on that info.
Old 04-21-2009, 03:52 PM   #13 (permalink)
Synthetic
Get your point,I usely do the 5000 mile thing,sometimes less ,sometimes more.Fact is,anyone that has a high milg. car,did it .We used synthetic oil on B 52"s back in 67/68,so it has been around a long time.Allways wondered what would happen if I put that stuff in my Ford 260 v/8,but I don't think it was multi grade .Not the same as a j57 engine.
Old 04-21-2009, 04:27 PM   #14 (permalink)
Other than the Germans' WWII exigencies, synthetic lubricants were first used here as aviation turbine oils, partucularly because of the extreme viscosity properties. That "Buff-Hotels" are still a mainstay confirms that synthetics in their case have done their jobs.
act in haste, repent in leisure
First Oil Change -- Can this be right? Prospero smart Operation and Maintenance 38 10-14-2009 03:11 PM
first oil change question - should i get an adapter for regular filters? britboy smart General Discussion 9 12-04-2008 08:37 AM
Oil Change donaldej3733 smart General Discussion 31 12-01-2008 12:58 AM
Oil Change Ron F smart Operation and Maintenance 9 10-25-2008 04:29 PM
oil change SmartDigger smart Operation and Maintenance 9 04-11-2008 10:48 PM
