Oil Drain Plug Screen - Smart Car of America Forums : Smart Car Forum
Old 02-07-2008, 11:33 AM   #1 (permalink)
what's the purpose of the screen attached to the end of the oil drain plug,, it's about 3/4 in in dia. and 2 1/4 in long, it was as clean as could be, never seen this before, but this is the first time i changed oil in a mercedes product
SMARTIEPANTS is offline   Reply With Quote
Old 02-07-2008, 01:43 PM   #2 (permalink)
gamernotwatcher's Avatar
How many miles did you put on before changing?
Old 02-07-2008, 01:51 PM   #3 (permalink)
Sounds like it might fit over the end of the suction tube (to keep crud out of the oil pump)??
Procrustes is offline   Reply With Quote
Old 02-07-2008, 02:40 PM   #4 (permalink)
GHammerly's Avatar
There is a picture some where that shows a cutaway view of the Mitsubishi motor and it's clear that the oil pan is also the oil pick up tube for the oil pump, the screen is visible too in line with the oil drain plug.
Like Procrustes said, keeps the big stuf off the pump.
Gus
Old 02-07-2008, 03:24 PM   #5 (permalink)
Dave777's Avatar
Gus
I'd like to see that cutaway picture if you can find it. Thanks.
Old 02-07-2008, 03:37 PM   #6 (permalink)
smarterer's Avatar
Section views through the smart engine
Here is a web site that shows the cut-away you are looking for, and also has a lot of other great pictures / wallpaper.
http://www.seriouswheels.com/cars/to...art-Fortwo.htm
It sure looks like the oil is "pulled" into the engine through the screen, but with no oil pump being shown I could be wrong.
smarterer is offline   Reply With Quote
Old 02-07-2008, 03:49 PM   #7 (permalink)
changed the oil at 1008 miles, if i had it to do over again i think i would of done it at 500 miles,,, a little more shiney stuff in the bottom of the drain pan than i expected
Old 02-07-2008, 03:59 PM   #8 (permalink)
yep that's it, you can see it in the cutaway, but we don't have the ribbed belts, do we ?
Old 02-07-2008, 04:02 PM   #9 (permalink)
Dave777's Avatar
Thank you for that! I was hoping something that also showed the cylinders and valves better too. But that's good stuff.
Old 02-08-2008, 10:36 AM   #10 (permalink)
roverallover's Avatar
what did you retorque the drain-plug to? I'm changing the oil as we speak (and making a video to post).
roverallover is offline   Reply With Quote
Does the 451's have a drain plug? Smartfor2guy smart Operation and Maintenance 2 02-01-2008 04:49 PM
No oil drain plug in earlier SC's?? doc540 smart Operation and Maintenance 7 01-27-2008 01:02 PM
Oil pan w/drain hole and magnetic drain plug jwight Original (450) smart fortwo 11 12-18-2007 10:27 AM
interesting screen saver ifishcat smart General Discussion 0 11-16-2007 04:25 AM
Volvo Unveils A Plug-In Hybrid SMART The Car Lounge 3 09-21-2007 07:04 PM
