Oil filter - Smart Car of America Forums : Smart Car Forum
Old 04-15-2009, 12:29 PM   #1 (permalink)
Oil filter
Expect to change oil ,for the first time,in about two weeks.Any word on replacement filters.Dealer 300 miles away,won't go back unless it needs to be towed.Sure it must be a standard filter,but which one?
bob/cathy is offline   Reply With Quote
Old 04-15-2009, 12:55 PM   #2 (permalink)
WhiteNBlack08's Avatar
I personally use a Mobil 1 M1-108, but you can use any comparable filter. Here is a thread with a list of compatible oil filters:
Where to buy oil filter?
And here is the big one:
List of motor oils and oil filters:
Old 04-15-2009, 01:22 PM   #3 (permalink)
Personally, I would not use the identical Wix 57040 or NAPA 7040 filters if anything else was available. They are ordinary paper-medium filters, and their 8psi bypass valve spring rates are way below the OE's 18psi.
Old 04-15-2009, 05:05 PM   #4 (permalink)
donnyonee's Avatar
ill ditto the m1-108 and 0-40 wt mobil1 oil.
imho its second to none.
Old 04-15-2009, 07:14 PM   #5 (permalink)
SmartDigger's Avatar
I did mine today. Mobil 1 M1-108 and Mobil 0-w40 syn. oil. Mine took 4 qt. though.
Old 04-15-2009, 07:19 PM   #6 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...did you remember to put the plug back in before you started to service it......after a long,long drain time and a warm up, 3 1/2 was all it took to get to full warm....go figure...
jetfuel
Old 04-15-2009, 07:23 PM   #7 (permalink)
I was doing some other things around the house. opened the drain and let it drain for over a hour. It dripped fpr ever. That could be the dif.
Old 04-15-2009, 07:28 PM   #8 (permalink)
Padawan's Avatar
That's a bit of a stretch, but the Mobil 1 0W-40 is a very decent oil. I used it on my initial oil change at 5000 miles along with an OEM smart (Mitsubishi) filter, but I'll likely go with something different next time, at least as far as the oil is concerned.
Padawan is online now   Reply With Quote
Old 04-15-2009, 07:40 PM   #9 (permalink)
...why?
jetfuel
Old 04-15-2009, 08:06 PM   #10 (permalink)
If you put in 4 qts, it is probably over-filled. It should be just below the full mark.
K&N air filter ASmartMan Dealers and Parts 10 10-08-2009 07:38 AM
Where to buy oil filter? paroyboy smart Operation and Maintenance 13 03-01-2009 05:26 PM
$22.00 For An Oil Filter UR2SLOW1 smart Operation and Maintenance 13 04-19-2008 03:01 PM
