P0440 OBDII Code Evap Control Sytem...Incorrect Purge Flow - Smart Car of America Forums : Smart Car Forum
Old 10-05-2009, 10:15 PM   #1 (permalink)
So my check engine light is on on my 2006 SmartCar Passion and my mechanic ran the OBD coming up with this code (P0440 OBDII Code EVAP Control Sytem...Incorrect Purge Flow). Given the newness of the SmartCar operations and with no local parts available, he wasn't quite sure what to do. The car runs fine...the check engine light is just on continuously.
Any suggestions for further repair/diagnosis?
chandler is offline   Reply With Quote
Old 10-05-2009, 10:30 PM   #2 (permalink)
Clear the code and see what happens!! It may have only been a momentary problem.
Old 10-05-2009, 10:34 PM   #3 (permalink)
how do you clear the code?
Old 10-05-2009, 10:47 PM   #4 (permalink)
You have a mechanic who can read the code but can't clear the code?
Here's a link to try Scangauge and clearing smart scan codes
Old 10-06-2009, 08:24 AM   #5 (permalink)
Yes, by all means get a new scangauge and a new mechanic
Old 10-11-2009, 07:15 AM   #6 (permalink)
Leroy's Avatar
There is a fix for this problem on the G&K cars if that is what you have. PM me and I will tell you the fix. But first make sure the fuel cap is on tight. Also check to see if there is fuel in the charcoal canister. There are lots of things to check for problems and all are under the car next to the fuel tank.
Leroy
Leroy is offline   Reply With Quote
obdii code P0887 TCM Power Relay Control Circuit High pitstopautoinc smart Operation and Maintenance 6 09-04-2009 03:37 PM
Check engine CODE P0497 Evaporative Emissions Purge Valve wrumbarger smart Operation and Maintenance 8 05-19-2009 07:02 AM
mass air flow sensor smartHHO smart Operation and Maintenance 8 04-29-2009 04:07 AM
Purge Valve exonerated. a2jack smart Operation and Maintenance 10 11-27-2008 12:22 AM
Breathless high flow air filter coming soon. lowndex smart Modifications 19 10-05-2008 12:47 PM
