Passenger Brake Caliper not fully releasing - Smart Car of America Forums : Smart Car Forum
Old 03-22-2010, 12:10 AM   #1 (permalink)
stagetech's Avatar
Greetings Everyone, I have an interesting issue. The passenger disc brake caliper is not fully releasing causing the brake pads to rub the rotor. This is very apparent when driving under 10mph. To confirm this I put my 09 Passion Coup up on the lift and the drivers front wheel made no noise and spun freely. The Passenger wheel did not spin freely and an audible brake pad rub was present for the full wheel rotation. The brake pads are worn less than 1.5mm from new and the brake fluid is clean and at the proper level. There is no visible damage to the brake line nor the caliper. I took the car into the Universal City dealership and the tech said this is normal and to live with it. I say B.S.!!!!!! (I have worked all sorts of cars and commercial vehicles not to mention the two 1950's Mercedes that I have restored). My car just rolled over 17,600 miles and I think that this should be covered under warranty. I am thinking of dropping by Smart Cerritos. Any thoughts?
stagetech is offline   Reply With Quote
Old 03-22-2010, 04:41 AM   #2 (permalink)
disc brake pads shoulld drag lightly and not fully release.
Old 03-22-2010, 06:39 AM   #3 (permalink)
The additional drag from disk brakes is one of the reasons you find drums on the rear of the smart: for efficiency. Some drag is expected with disk brakes because calipers cannot guarantee a full release. But then again they shouldn't drag *hard*. The question that needs to be answered: "how bad is it?"
Old 03-22-2010, 09:26 AM   #4 (permalink)
stagetech's Avatar
Hi John, I know that there should be a little drag in the calipers but the drag is enough to pull the car to the right slightly when driven at slow speeds (under 20 mph) and when light braking is applied. There is no noticeable pull when harder braking is applied (and before anyone ask... the alignment has been checked and is well within tolerance). As for your question on how bad is it... if I wipe down the brake dust on both wheels and drive by 65 mile one way commute, the passenger wheel is covered in brake dust by the time I get to work while the drivers wheel has barely any brake dust on it. My commute is 98% freeway and not in traffic so braking is below minimal. I know that something just isn't right and I want to tackle the problem before it gets worse or my warranty runs out.
Old 03-22-2010, 09:27 AM   #5 (permalink)
If the drag is noticeable when under ANY engine power it is probably too much. If you are feelng brave go for a quick ride with no heavy braking then pull over and touch both front wheels (carefully). If the suspected brake dragger is much warmer I'd suspect an issue worth pursuing further.
DominicRI is offline   Reply With Quote
Old 03-22-2010, 09:45 AM   #6 (permalink)
or use a digital no-touch thermometer...
Old 03-22-2010, 09:53 AM   #7 (permalink)
What fun could that possibly be?
Old 03-22-2010, 10:33 AM   #8 (permalink)
Mad about smarts and Cats
BB Benz's Avatar
Blackwell, Putt-Putt, Spice
Blackwell, kheran, MJB are you guys watching this?
That auto-erotica theme is rising again!
Can you feel it?
I felt it!
It's gettin hot in here.
Could be a real drag on fuel economy.
Old 03-22-2010, 11:09 AM   #9 (permalink)
I'd suggest you call the Smart Center back up and speak with the service manager to explain to the person the severity of the problem as you just now described it explaining that you know a little drag is expected.
If the service manager isn't responsive, find your next closest Smart Center and give their service department a call.
If you still get no satisfaction, consider placing a call to SmartUSA.
Old 03-22-2010, 11:25 AM   #10 (permalink)
silverbrabus's Avatar
Check it yourself.
Seeing as you're in SoCal, shouldn't be corrosion. Probably just sticking caliper sliders. Pop off the wheel and take a look. Silicone grease if needed. If something serious can describe defect to smart service.
brakes, caliper, warranty
G2 Yellow Caliper Paint and Black Drums tigerwong58 smart Modifications 12 01-01-2010 07:20 PM
Brake Cleaner and Caliper paint jediknight36 smart Operation and Maintenance 12 09-22-2009 01:03 AM
Caliper to Piston Seals branded68 smart Operation and Maintenance 5 09-03-2009 01:52 AM
Custom Smart Caliper Tekiuwa smart Wheels & Tires 0 04-03-2009 04:00 PM
smart USA's poor performance releasing 09 info jwight smart General Discussion 20 10-25-2008 01:54 PM
