HOME FORUMS GALLERY CLUBS
Music Game
Old 09-06-2008, 07:33 PM   #1 (permalink)
DeInNC's Avatar
Drive: smart passion yellow/black
Passion hatch window is marring the body panel!
We've had our Passion for over 7 months. Just noticed last week while washing her that the rear window glass is rubbing the body panel on one side and is leaving a mark. Other side is fine, so am thinking the alignment has shifted. Also have noticed an intermittent "buzzing" that seems to come from the black cover that is inside on the upper part of the rear window. Could be related, I suppose, as it's on the same side.
Has anyone experienced or heard of an alignment issue with the back window? Is there any adjustment I can make? May have to cave and take her in to the dealer.
Thanks.
DeInNC is offline   Reply With Quote
Old 09-07-2008, 01:24 AM   #2 (permalink)
Modérateur
Drive: w/s/r 08 passion
Unfortunately yes!
See:
Uneven upper tailgate
So, it seems that it's an easy fix by your Dealer. Or a DIY, though the thread didn't give a step by step guide... (If I remember correctly).
Old 09-07-2008, 06:03 AM   #3 (permalink)
Nicholas / Linda
Nicholas's Avatar
Drive: 2006 Honda Ridgeline
"It is a very simple fix, requiring only an 8mm wrench (incorrect tool, but it fits fine) to loosen the two bolts in the bracket going into the glass mount. With the gate open, loosen, slide the glass toward the front of the car and snug the bolts. Close and compare the gap across the bottom. Rinse and repeat. When everything is even, tighten the bolts snugly without wringing them off.
Just have a little patience and don't assume a single "loosen, move, tighten" sequence will put everything in the proper alignment".
This was an earlier "quote" on 6-20-08 11:07AM from "bull8208" under the heading. "Uneven upper tailgate".
The proper tool is a 8mm E-torx wrench to be able to fit between the hatchback top lip and the inside of the rear window...but please don't tell anyone that I told you a 5/16" box wrench will do the same thing. Takes about fifteen minutes even taking your time doing a few adjustment tries. Good luck...
Old 09-07-2008, 06:24 AM   #4 (permalink)
bradgarbus's Avatar
Drive: Towncar 1996
BAD ROBOTS!
Old 09-07-2008, 06:26 AM   #5 (permalink)
Not Selling on Ebay
Drive: 2006 Mini CVT
I don't have the issue with the window rubbing the body panel, everything is aligned. I do have the buzzing coming from the black cover that is inside on the upper part of the rear window. Not sure how to fix it. I wedged paper towels up there when it starts buzzing to stop it. It is VERY annoying. I haven't had time to take the cover off.
Old 09-07-2008, 07:16 AM   #6 (permalink)
mike-in-sa's Avatar
Drive: 2002 T-Bird GMC P/U
Sorry bradgarbus, this portion of the smart is built by humans,not robots. Maybe too much wine at lunch!
Old 09-07-2008, 03:20 PM   #7 (permalink)
DeInNC's Avatar
Thanks everyone for the tips. I missed that thread so will check it out. Sounds simple so I will give it shot first, then call the dealer if I can't get it.
Yes, the buzzing is very annoying - I looked for something to tighten up but couldn't find it so I also am headed to the "paper towel" fix at least for now to keep some sanity.
Forum Jump
3 window hatch jwight Original smart fortwo 12 08-17-2008 09:48 AM
Will Smart sell me 1 body panel, or do I have to buy the whole kit? Gregc Smart Car General Discussion 3 05-31-2008 11:01 PM
Individual body panel purchase prm1177 Smart Car General Discussion 38 04-13-2008 04:40 AM
body panel pics whirlybirdpro Interior & Exterior 2 03-27-2008 07:36 AM
Body Panel Pricing Smartarse Smart Car General Discussion 11 03-24-2008 07:50 AM
