"It is a very simple fix, requiring only an 8mm wrench (incorrect tool, but it fits fine) to loosen the two bolts in the bracket going into the glass mount. With the gate open, loosen, slide the glass toward the front of the car and snug the bolts. Close and compare the gap across the bottom. Rinse and repeat. When everything is even, tighten the bolts snugly without wringing them off.
Just have a little patience and don't assume a single "loosen, move, tighten" sequence will put everything in the proper alignment".
This was an earlier "quote" on 6-20-08 11:07AM from "bull8208" under the heading. "Uneven upper tailgate".
The proper tool is a 8mm E-torx wrench to be able to fit between the hatchback top lip and the inside of the rear window...but please don't tell anyone that I told you a 5/16" box wrench will do the same thing. Takes about fifteen minutes even taking your time doing a few adjustment tries. Good luck...
