Thanks to the instructions in the first message it was a snap. Much thanks. The only difficult one was the plug to the right. Getting that little 10mm retaining bolt out was a pain, I could get a small 10mm wrench in there and get it started but it was still to tight to take out with my fingers. So, I got a strong pair of needle nose pliers that have the tip bent almost 90 degrees and that was able to get in and get a few more turns to make it removable by hand. Took about 30 mins total time. And on the other two bolts I used a 10mm socket with a 1/4 inch ratchet. Not the wrench.
It's not the mind blowing difference you'd expect from reading some of the reviews about the iridium plugs, but there is definitely an increase in acceleration. My smart runs smoother now and feels like it did when I first drove it off the lot.
I took a pic of my old plugs, but I do not have enough posts to insert a link. Maybe I'll post right after this one
