Old 06-28-2008, 04:18 PM   #11 (permalink)
interested
Originally Posted by jonnysan View Post
The leak exposes itself when you open the hatch and water pees out of the upper left corner of the hatch frame. Dealer replaced the hatch. 4200 miles
Awaiting replacement of shade ....parts ordered. Same failure mode as many others have had.
smart center of latham rated ....A+
John
I am interested to hear more of this, mine was doing this the DAY I picked it up and the dealer said it wasn't an issue. Well, everytime I wash it, this thing keeps dripping and draining onto the left side.
tivoboy is offline   Reply With Quote
Old 06-28-2008, 08:20 PM   #12 (permalink)
Interior motion sensor for the alarm was causing false alarms starting around 60 miles, basically the day after driving it home from the dealer. Originally the part was supposed to be waiting when I dropped off the car. Ten days later it still hadn't arrived so they deactivated the motion sensor and I picked up the car. When the part eventually arrived, it was about a 90 minute wait to get it swapped out. No problems now for 10 days anyway. Giving them the benefit of the doubt about not knowing they couldn't get the replacement part before I dropped it off, they get a "B." If they actually knew about the part problem, an "F."
Old 06-30-2008, 04:04 PM   #13 (permalink)
Drive: 2008 smart & 2007 Subaru
Blower motor and microwave switch
Well at 2918 miles and approximately one month of ownership the blower started working intermittently. And to get the alarm system not to go off on it's own, I'd have to push the "tow" button on the dash before setting the alarm.
My guess for the blower motor was a loose connection between the switch on the dash and the motor - BINGO absolutely correct.
In the forums here was a report of someone having the same (similar) problem with the alarm and it being the "microwave sensor" - BINGO absolutely correct. The loose connection was fixed today and the replacement microwave sensor has been ordered and should be in on Wednesday. Service has to be rated at an A.
The whole process took from 10:40 am till 5:00 pm, a break of about an hour for lunch was in between and the service tech started on it at 11:00 am. Glad the clock was running on smart USA's dime 5x70%x$100= $350 ?????.
Also earlier, about 2000 miles, had the P0410 Secondary Air Injection System Malfunction that was fixed the same day as taken in. - Again Thanks to this forum and my Scangauge II.
Chassol is offline   Reply With Quote
Old 06-30-2008, 04:24 PM   #14 (permalink)
Dave777's Avatar
Drive: 2008 smart Passion
At about 40 miles I had an electronic module in the shifter go bad. This is not the usual stuck shifter, but an electronic issue.
SmartcenterSeattle handled very promptly. A grade.
I'm having the AM radio poor reception issue, and they're, hopefully, going to replace the AM amplifier. Will let you know if that solves the issue.
Dave777 is online now   Reply With Quote
Old 07-01-2008, 11:30 AM   #15 (permalink)
Fredvon4's Avatar
AT 2275 Farnsworth threw the dreaded CEL
Smart Center Round Rock 75 miles away
Drove down after calling ahead
secondary air control valve failure
5 min fix
in and out under 1 hour
Not happy that is failed
Very happy with the service
Would be nice to have a more local dealer
Up coming problems I will get fixed under warranty ...some day
Not in any order
AM radio section if FUBAR in Radio 10 (may-haps AM antenna amplifier fault)
Green House sun shade is starting to act up and bunch up.... arrrgh!
I constantly smell burnt clutch smell when I put cargo in the rear boot
Passenger side roof/door/trim rattle
Mirrors shake too much at certain speeds
Drivers mirror assy outer cover has something wrong... cover flaps a LOT at 70~75 MPH.. (I suspect broken tabs internally from assembly of the cover)
Old 07-01-2008, 11:36 AM   #16 (permalink)
Any photos of this mysterious air control valve out there? Sure would be nice to see it "in the flesh."
Old 07-04-2008, 10:46 AM   #17 (permalink)
smartist's Avatar
Sun Shade Replaced
No hassle replacement of sun shade at San Diego smart center, but new one just as bad. More convinced than ever that an inherent design flaw results in shade shrinkage and consequent binding.
Rick
smartist is offline   Reply With Quote
claims, dealer, repairs, service, warranty
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/post-your-warranty-claims-9906/
Smart Car Blog: Smart Car Accessories This thread Refback 06-22-2008 05:38 AM
Warranty Carnut Smart Car Operation and Maintenance 56 07-16-2009 04:43 PM
