Old 10-19-2009, 04:22 AM   #1 (permalink)
ulflyer's Avatar
Drive: 08 Cabrio, Yellow
Pucks & Wheel Torque for Commercial Tire Stores
What do you folks do when you take your car to a commercial tire place and they put it on thier 4 point lift? Do you provide 4 pucks/wood blocks for them to use?
Also, what is the torque value for the wheel nuts? Any different from "normal" wheels installed by the commercial places ?
ulflyer is offline   Reply With Quote
Old 10-19-2009, 05:16 AM   #2 (permalink)
Midwest Club Organizer
jefferios's Avatar
Drive: Blue '08 Passion
When my car had to swap tires they just used a jack for each corner.
Old 10-19-2009, 05:24 AM   #3 (permalink)
Old smart's Avatar
Drive: fortwo premium coupé
Torque
Wheel bolts: 81 ft-lbs (110Nm).
Old 10-19-2009, 07:11 AM   #4 (permalink)
watch out for fools with stud twisting air wrenches
3slndr is offline   Reply With Quote
Old 10-20-2009, 04:24 PM   #5 (permalink)
ulflyer's Avatar
Thanks guys for the info. One more question on lift points:
Can the large horseshoe shape tube under the rear but used by the commercial lifts as a lift point?
Reason for all the questions is I expect to have some wheels installed soon and doubt seriously if the tire dealer I use has ever serviced a Smart.
Old 10-20-2009, 04:32 PM   #6 (permalink)
JOIN SCOA..YOU'LL BE GLAD
Drive: modified 65 stang conv
do not use the swing arm for a lifting point...it is coated to protect it from the elements...any scratches in there and "hello corrosion"....if your tire shop can not use the provided lifting points move on...or teach them the right way...after all ...you're paying good money for the service and the customer is always right...
jetfuel...right some times
Old 10-21-2009, 04:10 AM   #7 (permalink)
ulflyer's Avatar
Jetfuel: Good point about scratching. I've been dealing with the shop for years and they will do whatever I ask; just want to be prepared to guide them the right way. Ha. I've cut out some wood blocks for the front but the rear point isn't as large. I'm guessing that jacks made for the Smart has some sort of neoprene cup that fits over the lip of the lift?
Old 10-21-2009, 07:37 AM   #8 (permalink)
Pics posted in an earlier thread show that the dealers' lifts have small metal disks that fit into each of the four points.
OEM Wheel / Tire for 450 Wanted RIderInTX Original smart fortwo 1 07-22-2009 10:42 PM
Wanted: Wheel, OEM, with or without tire, for 450 RIderInTX Smart Car Parts Marketplace 0 07-03-2009 11:02 AM
Sound Advice closing all stores. cubefx Tech & Gadgets 0 11-26-2008 06:54 PM
I need a front tire/wheel.. gusfraga Smart Car General Discussion 1 11-08-2008 07:56 AM
Wheel and Tire Package Anyone? Vlad92 Smart Car Delivery 3 01-30-2008 07:41 PM
