Puny air conditioner - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 06-14-2009, 11:18 AM   #21 (permalink)
Sounds like a problem with the automatic control system. It "thinks" all is well and cuts back cooling. temp sensor? air door alignment? software? Would be nice to have a shopmaual.
Old 06-14-2009, 11:18 AM   #22 (permalink)
JimDantin's Avatar
Dancote -- that was exactly my issue. have your dealer talk to the service manager at smartcenterlouisville (Shawn). make him do it before you go back, and make him get a replacement control module in stock.
After mine was fixed, it works great and holds the cabin temperature very constant. The A/C shifts itself into max mode when I first get into the car in hot weather, then throttles down when it reaches the temperature on the selector lever. It blends hot and cold air, and also cycles the compressor as needed. This is a very sophisticated system.
The Following User Says Thank You to JimDantin For This Useful Post:
BB Benz (07-24-2011)
Old 06-14-2009, 08:34 PM   #23 (permalink)
dancote's Avatar
Thanks Jim,
I'll pass this along.
Regards,
Dan
dancote is offline   Reply With Quote
Old 06-17-2009, 11:28 AM   #24 (permalink)
The A/C itself seems to work fine. However the "climate control" seems to be at fault on my '09 Passion Coupe. For example, I tested it this morning. Outside temp was 83. I drove for 20 highway miles to equalize everything with the climate control set at 65. The inside cabin temp would not drop below 80. And it's not even hot outside yet!
However, the air temp at the vents was right at 65. So I'm thinking the "climate control" temperature is really the vent air temperature. Perhaps the sensor that controls it is not located properly? Or maybe it is simply adjusted incorrectly?
Advice would be appreciated as I would like to take it to the dealer once to get it fixed and not make a lot of return visits.
Thanks in advance!
nedhedrick is offline   Reply With Quote
Old 06-17-2009, 11:43 AM   #25 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
Sounds like the temp at some of my vents. From my on-going AC saga, I've learned that the temp at the vents should be in the 40s if all is working well. Unfortunately, there are a myriad of parts involved with this system, so it could be as simple as low on refrigerant to AC control module to whatever. In my car, they believe the problem is an expansion valve since everything else has been replaced. You'll have to go back for service and, if possible, I would try to leave it with them until it's fixed in case its something odd. Just my .02...
Old 06-17-2009, 12:07 PM   #26 (permalink)
Originally Posted by piglith View Post
As far a thread title all's I can say, It's a Puny car, how could you expect more?
Couldn't agree more!
Having said that, since the puny A/C has to cool only a puny volume of air, our A/C is entirely satisfactory for our So. Fla. weather.
Even on the hottest days, after sitting in the sun for hours, you may only have to open the convertible roof for a minute or two while running the A/C at max fan speed for a couple of minutes. After that, in the worst heat last summer I was able to dial it down from the max fan speed to the next lowest, and even lower unless the car got stuck in traffic.
vwW12 is offline   Reply With Quote
Old 06-17-2009, 12:26 PM   #27 (permalink)
Jim, can you describe "max mode?" If it's what I think (high fan, max cool) neither our 08 nor the 09 did/do that automatically, not matter how hot the cabin is.
Old 06-17-2009, 12:49 PM   #28 (permalink)
John,
I do believe you are correct in Jim's answer. Mine does the exact same thing
When I first turn it on, it's "max" with high fan and recirc (no matter what the settings are) then after a couple of minutes it turns itself down. Gotta love the "comfort package"
Old 06-17-2009, 04:08 PM   #29 (permalink)
JimDantin's Avatar
Yep -- that's what it does. I am SO happy with its performance. I keep it on 65 or 68 and stay nice and cool. Of course, my wife is always cold!
I can't stress too much how important it is to get the dealer to test it properly (computer hooked up, recalibrate the climate system with a computer command, put thermometers in the air vents and in the cabin (my dealer used an infrared instant read thermometer to check cabin temp), close the doors and windows with the A/C running and watch it. It should put out colder air than the selector is set for until cabin temp reaches the selector temp. Then the vent air temp will rise until equilibrium is reached. You should be able to watch it cycle. Open the door to warm up the cabin a bit and you should see colder air from the vents.
When I get into the car after it is sitting in hot sun, it definitely starts off in recirculate and high fan until it cools off. Then it automatically switches to whatever fan speed I have selected and switches out of recirc mode. My car is a 2008 black passion, so it gets really hot in the sun -- but it's nice and cool in just a few minutes of driving.
If your car is not performing this well, COMPLAIN LOUDLY!
Old 06-22-2009, 10:41 AM   #30 (permalink)
Check the Air Blue thread in mods section/interior/ext. Hope it helps and you get your problem fixed. Cheerz, SmartChip
SmartChip is offline   Reply With Quote
Is your Air Conditioner freezing up / not cooling? JusNameMe smart Operation and Maintenance 37 10-07-2010 08:20 AM
Air conditioner question tablepad smart General Discussion 1 08-20-2008 01:22 PM
The Oddities of Driving a Puny Car angel smart News & Rumors 8 06-21-2008 04:08 PM
Air Conditioner Performance MichaelJ smart General Discussion 50 05-31-2008 07:56 AM
Does 'defrost' setting, use air conditioner? mr_Cash smart Operation and Maintenance 15 03-06-2008 05:12 PM
