Question about a light on my Instrument Cluster - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 09-05-2008, 04:18 PM   #11 (permalink)
shack01's Avatar
If you inflate the tires to the correct pressure and the light stays on, probably a bad TPMS sensor.
Gosh jwight, way to spoil the mood by reading the manual.
On a serious note, the previous poster is correct that inflation pressure is very important. I've found over the last 6-7 months that Maxwell's tires leak at a rate of 2psi / six weeks. (Sorry Dave777, don't have the spreadsheet to back that up. ) Invest in a decent tire gauge and check them on a regular basis.
tm
shack01 is offline   Reply With Quote
Old 07-17-2011, 02:42 PM   #12 (permalink)
Hi there,
My TPMS light was on the other day and so I checked the tire pressure on all 4 and they are all normal! I reset the TPMS as suggested by the owners Man. A few hours later the light came back on again? I check the tires again and no loss of air? Has anyone else had this issue?
mog0070 is offline   Reply With Quote
Old 07-17-2011, 03:04 PM   #13 (permalink)
rchan's Avatar
I had to reset mine couple of times to get rid of the light, or else, you've a bad sensor.
rchan is offline   Reply With Quote
Old 07-17-2011, 08:01 PM   #14 (permalink)
I had the same problem about a year ago. I found out my tire pressure gauge was inaccurate, Get a good quality digital gauge and re-check the pressure.. The light will go on if tire pressure is too low OR too high..
Tail Light & Brake Light Problems smartass1 smart General Discussion 6 09-05-2010 10:30 AM
Instrument Cluster Display Problem factor9 smart Operation and Maintenance 6 05-03-2008 10:14 AM
Instrument Pods Old smart Audio & Video 18 02-07-2008 03:44 PM
