Old 10-13-2009, 06:40 PM   #11 (permalink)
JOIN SCOA YOU'LL BE GLAD
Drive: the hell out of it...
it could but if it is the plastic frame from the dealer it is screwed right into the back panel...plastic...
jetfuel...screw driver time bud...Where are those ice cubes at?
Old 10-13-2009, 06:52 PM   #12 (permalink)
Drive: Smart, BMW M3, Ducati 999r
I guess so but it is only secured on top, thats why I was wondering. you are right though about the plastic.
dvskier is offline   Reply With Quote
Old 10-13-2009, 06:56 PM   #13 (permalink)
...secure the bottom with some double backing tape and give it a try...
jetfuel...get'r'done
Old 10-13-2009, 07:11 PM   #14 (permalink)
It's worth a try, thanks.
Old 10-13-2009, 07:49 PM   #15 (permalink)
HGB
Drive: A6 & a little red + black
Is the engine getting hi-test at all times? Just a thought.
Old 10-13-2009, 08:29 PM   #16 (permalink)
Quagmire's Avatar
I had the same rattle (buzzing sound) on acceleration. Turned out to be the top frame of the rear window. Have someone put their hand on it when your driving. I put a felt pad between it and the glass; to solve the problem.
Drove me nuts... I thought it was a heat shield or loose licence plate.
Old 10-13-2009, 08:29 PM   #17 (permalink)
Always gets premium.
Old 10-14-2009, 06:31 AM   #18 (permalink)
HGB
When the smart is driven gently and the transmission chooses 5th gear early to save gas, any acceleration then will cause a resonating on various components. An example would be a vibrating mirror.
If the transmission would be dropped to the next lowest gear, the engine rpm would rise a bit and the rattling may stop.
I have a little MAZDA B2000 truck and when I shift to a high a gear at a low speed, the little 4 banger with minimal torque causes the whole interior to vibrate so harshly that I must immediately drop down to the next gear. I wonder if this phenomenon is your problem, especially since the dealer is not concerned.
Old 10-14-2009, 06:38 AM   #19 (permalink)
I am sure that is it with mine. Only at low speed on takeoff moving slowly. This car has a lot of parts that are not bolted and it can be just a little noisy at times.
Duckhunter is online now   Reply With Quote
anyone else have a rattle? ronstaug Smart Car General Discussion 30 10-25-2008 09:41 AM
Shake, rattle, and roll.... saxdiva California Chapter 14 07-31-2008 04:13 PM
ESP flickers, rattle at drivethrough NCC1701 New Members Area 7 07-14-2008 08:58 AM
Rattle on right side curlyp Smart Car Operation and Maintenance 15 06-12-2008 02:15 AM
Closing Door Rattle excessive nex1 Smart Car General Discussion 21 03-10-2008 09:34 AM
