Resetting faulty TPMS telltale - Smart Car Forums
 3Likes
post #1 of 18 (permalink) Old 03-01-2014, 04:29 PM Thread Starter
Quoted: 1 Post(s)
Can anyone share instructions on how to reset a false TPMS malfunction telltale?
Pressure is perfect and the darn light won't go out. Short of putting black electric tape over the the warning light, I'm at a loss. It did happen once before couple of years back, and it was reset by the dealer.
I have 2008 Smart forTwo Passion. Thanks in advance!!!
skyMyrka is offline
post #2 of 18 (permalink) Old 03-01-2014, 04:40 PM
Quoted: 147 Post(s)
Double check that the pressures are where you want them to be, then hold the TPMS button in for 5 seconds (until warning lamp flashes) with the key on.
But ... If that procedure does not reset the warning lamp, you probably have a bad tire pressure sensor. If they are the original sensors, they have a battery in them, and that battery is probably nearing the end of its life. Only fix then is to replace the faulty sensor.
SmartDigger likes this.
GoFaster is offline
post #3 of 18 (permalink) Old 03-01-2014, 04:42 PM Thread Starter
Quoted: 1 Post(s)
Thanks! I believe batteries are rated to last for 10 years(?). Would the sensor have to be replaced (boy they're not cheap) or there's a way to reset it?
skyMyrka is offline
post #4 of 18 (permalink) Old 03-01-2014, 04:44 PM
Jakieowner's Avatar
Quoted: 21 Post(s)
Sadly, you need to replace one or more tpms sensors (inside the tire(s))
If one sensor goes, it doesn't matter if you have correct air pressure or not. Dash light will stay on. I have one smart that has the remedy you mentioned. Black tape over the indicator. I think new fancy shmancy setups have individual readouts for
every tire, but not the smart.
Jakieowner is offline
post #5 of 18 (permalink) Old 03-01-2014, 04:48 PM Thread Starter
Quoted: 1 Post(s)
Jakieowner, yeah, looks like it's electric tape and $2 pressure gauge is the fix I'm looking for (for now).
Thanks!
skyMyrka is offline
post #6 of 18 (permalink) Old 03-01-2014, 04:50 PM
SmartDigger's Avatar
Quoted: 167 Post(s)
Tire centers have a tool that can check the tire sensor
SmartDigger is offline
The Following User Says Thank You to SmartDigger For This Useful Post:
skyMyrka (03-01-2014)
post #7 of 18 (permalink) Old 03-01-2014, 05:32 PM
Jakieowner's Avatar
Quoted: 21 Post(s)
Yes, smartdigger is right. My point sort of was, one goes out the light goes on. The next goes out the light goes on. It's a sort of all or nothing system
Checking your tire pressure every week or two is a low tech solution.
My other smart has all up and running. When the tpms fails (and they all do eventually) I'll probably just keep on check'in every week.
post #8 of 18 (permalink) Old 03-01-2014, 05:45 PM Thread Starter
Quoted: 1 Post(s)
The thing doesn't even tell the temperature. Makes sense for now just wait until the tires need to be replaced and do the everything all at once.
I like SmartDigger's idea to get them tested, but it also makes sense that even if one goes, chances are the remaining 3 are not that far behind.
Thanks everyone for the responses and crash course 101!!
skyMyrka is offline
post #9 of 18 (permalink) Old 03-01-2014, 08:07 PM
Quoted: 7 Post(s)
Battery
Can you hack the TMPS and replace the coin battery?
rubyg is offline
post #10 of 18 (permalink) Old 03-01-2014, 08:36 PM Thread Starter
Quoted: 1 Post(s)
Rubyg:
I've been trying to learn more about this (thanks to all that pointed me in a right direction), and it looks like the answer is no. And honestly I'm beyond shocked for all that it takes to correct depleted $3 battery!!
It's a good thing that malfunctioning tmps won't fail you at an inspection (at least for now), but in all honesty there's gotta be a better way to deal with this problem. I'm all for doing my own maintenance spark plugs/bulbs/oils/fluids/etc, but this is not something I can pull off in my garage.
The cheapest sensor I was able to find is about $60ea
skyMyrka is offline
tpms
Human Verification
331
Resetting the maintenance indicator redux... gbryers smart Operation and Maintenance 1 06-17-2013 07:50 PM
2012 Smart: resetting maintance schedule after oil change chiefneon smart General Discussion 7 07-29-2012 09:08 AM
Resetting service reminder in Smart for Two Passion stude55 smart General Discussion 1 07-06-2010 04:11 PM
Resetting the indicator Speedy New Members Area 2 02-01-2009 12:43 PM
Computer Resetting SBibbo smart Operation and Maintenance 3 06-08-2008 09:29 AM
