roof coming unglued - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 06-11-2009, 03:37 PM   #21 (permalink)
Owner for 3.8 years
Kermit's Avatar
Roof on national backorder!!?? Umm, Babybenz - do you have any insight? I do need to break away from up here and drive down to do my replacement for my roof, mileage isn't getting any less on the car as I need to continue driving it.
Old 06-11-2009, 10:04 PM   #22 (permalink)
Originally Posted by babybenz View Post
Ben Thomas is not the person to contact with this problem he is in charge of sales not getting the vehicle serviced
Heh, if you've ever worked in development or tech support you'll know one cardinal rule: Sales gets whatever results they want.
Threaten the salesperson's commission and they'll snap to attention faster than you can say "blog."
Old 06-12-2009, 01:14 PM   #23 (permalink)
Originally Posted by brett2658 View Post
i have had my car since the 18th of january and yesterday i found the the glue holding my roof has let go. The left front corner to the center is 12 inches. The lt front down the left side 18 inches. I called smart of dallas three times in two days and still no return call to make an appointment. How many times does it take to get a return call??????? it is a panorama roof
Have replaced 4 panoramic roofs here for just that problem. Has to do with an issue in the finishing phases of the frame. The clear coat pools up on in the corners and is not 100% cured when they lay the roof in, the bonding just does not attach. Takes about 2 hours to repalce and then has to set for 18 hours to completly cure.
smartSEATTLE is offline   Reply With Quote
Old 06-12-2009, 02:36 PM   #24 (permalink)
SmartTech's Avatar
if its just a glue issue why does the roof have to be replaced? couldnt they just take it off and reglue it?
Old 06-14-2009, 10:54 PM   #25 (permalink)
caroniaguy's Avatar
Having the exact same problem with my roof too. Glad to hear I'm not the only one. Have already called and left a message at the dealership and am taking it in first thing Monday morning. Thanks for all the info.
caroniaguy is offline   Reply With Quote
Old 06-15-2009, 03:23 PM   #26 (permalink)
caroniaguy's Avatar
Spoke with Service Manager this morning, he asked that I drop the car off, (they'll give me a loaner) and they will reglue the roof. Nothing was mentioned about replacement so I'm assuming they will reuse the roof I have...frm what I can tell there is nothing wrong with it, aside from it coming unglued.
Old 06-19-2009, 06:11 AM   #27 (permalink)
brett2658's Avatar
Well a week went by yesterday and still no roof. Sure glad the radio is loud to kill the wind nose from h3ll!!!!!!!
brett2658 is offline   Reply With Quote
Old 06-19-2009, 06:19 AM   #28 (permalink)
Looks like un-gluing issues can happen in small batches (like the one we had in '08 involving a couple dozen cars). Here's a '09 recall in the UK:
"Vehicle Details
Reference : R/2008/135
Manufacturer Ref : S041
Make: MERCEDES BENZ
Model : SMART - FOUR TWO
Launch Date : 19/01/2009
Numbers Involved : 26
Build Start Date :
Build End Date :
Recall Details Concern : WINDSHIELD MAY BECOME LOOSE
Description : Adhesion faults may occur between the individual paint coatings at the bonding surface of the roof and the windshield. Under extreme conditions this could lead to peeling of the roof or the windshield, which may lead to the windshield/roof becoming loose.
Remedial Action : Recall the vehicles that are likely to be affected to renew the paint work and bonding of the roof and windshield.
Old 06-19-2009, 10:55 AM   #29 (permalink)
caroniaguy's Avatar
Took my car in and they fixed the roof. Spoke with Mark at smart Bloomfield and he said they would just use the same roof and just re-epoxy it. So far so good. Also had them check a few minor issues, jiggley drivers side mirror and jangling noise (sounds like a metal cookie sheet with a bunch of loose nuts and bolts on it vibrating) under the car. my baby came back as good as new. I'm happy!
Old 06-22-2009, 12:43 PM   #30 (permalink)
Yes just a glue issue. The roof should be fine.
Panoramic roof vs solid roof? notbarb smart General Discussion 38 12-28-2008 08:24 PM
iQ Coming to US as Scion rfernatt The Car Lounge 34 10-21-2008 02:47 PM
My first oil change coming up..... blackbeagle smart Operation and Maintenance 6 09-18-2008 07:18 AM
It's coming faith in dc Mid-Atlantic Region 7 07-30-2008 01:41 PM
Top Gear USA coming to NBC jwight The Car Lounge 12 07-16-2008 10:31 AM
