Scan Gauge II set-up for smart car... - Smart Car of America Forums : Smart Car Forum
Old 11-16-2008, 06:55 PM   #1 (permalink)
Nicholas's Avatar
Purchased the Scan Gauge II for use in both the wifes' smart and my Honda Ridgeline. Finally figured out the set-up process to get accurate readings when in my truck but haven't got the process down quite yet for the smart. I do reset it to "Default" first, them engine size..1 liter, fuel used..gasoline, fuel tank size..8 gallons. Even got the backlight to match the dashboard. My problem is that when in the gauge mode and monitoring MPG, it reads ridiculously low. Anyone able to help me set-up the unit to read acceptacle mileage (I do know I'm in the 37 to 41 mile per gallon range)? Any help is greatly appreciated!!!
Old 11-16-2008, 07:52 PM   #2 (permalink)
Nicholas's Avatar
No suggestions?
Old 11-16-2008, 07:58 PM   #3 (permalink)
Here is a link ScanGauge II 4 451 Setup
Old 11-16-2008, 07:59 PM   #4 (permalink)
Hi Nicholas,
What kind of display are you using, the one with the four different readouts?
For the mpg i'm using the trip window it gives me a more accurate readout imo,
ostfriese is offline   Reply With Quote
Old 11-16-2008, 08:01 PM   #5 (permalink)
Oh by the way,i have set my fuel tank size to 9 gallons
Old 11-16-2008, 08:02 PM   #6 (permalink)
....and one more thing Go Gators ;)
Old 11-16-2008, 08:02 PM   #7 (permalink)
Scanguage sources
I went back and forth with Joey at their tech support. Mine was often way off, from -28% to +78% at fillup. I tried all their suggestions and never got a satisfactory result. It still works well as a relative guide for what's more fuel efficent and what's not, but I never got absolute numbers that consistently made sense.
Here are some threads on the subject:
ScanGauge II Setup...
ScanGaugeII XGauge Commands
P0410 Check Engine Error Code, Secondary Air Injection System Fault
Hope it helps
Old 11-16-2008, 08:59 PM   #8 (permalink)
try using a 10 gal tank.
Old 11-16-2008, 09:08 PM   #9 (permalink)
Default engine capacity being retained in memory?
I believe your problem is related to the default engine size being retained in memory, instead of what you entered.
I had trouble getting mine to reset after moving from one car to another. I had to unplug it and reset it two or three times before it worked.
After running the first tank through, there is a procedure for adjusting to the true amount of fuel used and it has been very accurate since.
If you need that procedure, PM me and I will run through it for you.
Old 11-16-2008, 11:27 PM   #10 (permalink)
Originally Posted by Nicholas View Post
No suggestions?
mine is on the shelf collecting dust again, fiddly and hard to read sorry not what you where looking for
Before I buy a Scan Gauge... garys smart General Discussion 14 02-23-2009 09:59 PM
Scan Guage II $160 - $50 GC w/FS! MB DNA smart Modifications 1 10-06-2008 12:22 PM
Scangauge and clearing smart scan codes Gene_SD smart Operation and Maintenance 1 08-18-2008 09:22 AM
Scan Guage II FS Hal2 Archive/obsolete (?) threads 0 08-12-2008 11:04 AM
Scan Codes ritchaso smart General Discussion 1 07-12-2008 06:26 PM
