Screw that holds down the gear shifter cover. Help! - Smart Car of America Forums : Smart Car Forum
Old 03-18-2010, 06:49 PM   #1 (permalink)
Planedriver's Avatar
I lost the original screw under my seat to the point of no return in the winter. The guy at Benz put in a new one for me when I had to bring it by once.
Today I needed to remove the cover again as I am peeling off the carbon wrap due to it deforming (as some on here said it would). I am doing a little orange theme to go with the outside.
I for the life of me CANNOT get this screw back in. I hate this design and find it sooooo bloody tedious. I fiddled with it for 1.5 hrs, ruining my freshly painted cover too.
So I ask ou guys, the experts, any tips?
I dont have a Tap that small with the thread thats on the bolt.
I have no idea how he got it in. any self tap screws?
notice the metal around the whole, that was there before.
The door handles came out as I hoped they would.
Rob.
Planedriver is offline   Reply With Quote
Old 03-18-2010, 06:56 PM   #2 (permalink)
JOIN SCOA.YOU'LL BE GLAD
..I know that you know but ....righty tighty lefty loosey...
...by the picture it is a tapping screw ...secure the screw to the driver with some masking tape ...that will hold it in place and keep you from loosing it...or use a magnetic tip driver...will the screw go in the hole all by itself?
jetfuel...where's my super glue at?
Old 03-18-2010, 07:16 PM   #3 (permalink)
Ya, you'd think. 1.5 hours and no go. Even LPS'd the whole and nothing.....
Old 03-18-2010, 07:27 PM   #4 (permalink)
..try a new screw ...maybe a # 6 PK ...one with a sharper end..
jetfuel...screw the glue...where's my welder at?
Old 03-18-2010, 07:27 PM   #5 (permalink)
Owner for 3.8 years
Kermit's Avatar
Walk away from it for today. Tomorrow you'll try it again and viola - it'll go right in! Happens to me all the time. I just walk away for a little while and regroup my thoughts. Whenever I come back to the job I magically get it perfect even though I spent forever earlier trying the same thing.
Old 03-18-2010, 07:30 PM   #6 (permalink)
stevet47's Avatar
seriously.. 1 1/2 hrs on done screw..damn.
I agree though, attach it to the tip of the screwdriver (tape, magnetic tip, etc). Sometimes it helps if you rotate a 1/4 turn or so counter-clockwise which lets the screw "fall" into its thread without trying to cut new ones, then turn clockwise to screw it in.
stevet47 is offline   Reply With Quote
Old 03-18-2010, 09:20 PM   #7 (permalink)
fastturb's Avatar
air gun
Old 03-18-2010, 09:31 PM   #8 (permalink)
SmartDigger's Avatar
Anything sticky to hold the screw to the driver. +1 on turning the screw counter clock wise 1/4 turn before turning clock wise.
Old 03-18-2010, 09:42 PM   #9 (permalink)
Originally Posted by fastturb View Post
air gun
jetfuel...3X gun ready..
Old 03-18-2010, 10:12 PM   #10 (permalink)
Thanks guys, Problem solved. I knew the original one was under the seat. 4 Torx bolts and 5 minutes later freed the original bolt by ousting the seat. Much thinner.
Engine cover fastener screw thing... theguywiththelongestname smart Modifications 48 11-30-2011 11:38 PM
Fog Light Mounting Screw Size? The Rigger Interior & Exterior 4 04-21-2009 08:20 AM
jammed gear shifter - stuck in N or D unicycle smart General Discussion 17 01-10-2009 07:01 AM
My gear shifter broke. Andrewlcox smart General Discussion 17 11-19-2008 11:45 AM
Screw these euro vendors! Frankenstein_Casanova smart Wheels & Tires 23 05-10-2008 11:10 AM
