Selves - from England (450 leaking coolant?) - Smart Car of America Forums : Smart Car Forum
Old 11-10-2009, 04:30 AM   #1 (permalink)
Hello Everyone - just joined recently. I have a 2003 reg. MCC Smartcar Pure, which I've had for 3 years now. Having a few problems with the coolant level having to be topped-up regularly. Any ideas on cause of this, will be much appreciated. Thanks to All.
selves is offline   Reply With Quote
Old 11-10-2009, 06:12 AM   #2 (permalink)
For all things smart: Evilution - Smart Car Encyclopaedia
chieftmc is online now   Reply With Quote
Old 11-10-2009, 07:44 AM   #3 (permalink)
Leroy's Avatar
Look under the water pump and see if it is driping. The water pump is close to the alternator. You may not notice the leak because the antifreeze leaks and then never hit the ground to show a spot.
If you have any more questions use the 450 forum of this site that way more people will see the problem.
Leroy
Leroy is offline   Reply With Quote
Windshield Washer Tank Leaking Okie Boy smart Operation and Maintenance 15 09-17-2011 06:12 PM
Oil Pan Leaking shark smart General Discussion 8 09-23-2009 06:16 AM
Hi I'm Hank (Q: 450 leaking oil?) beaudoin Original (450) smart fortwo 3 09-22-2009 11:16 AM
Problem with water leaking while washing Montana Smart 1 smart General Discussion 12 09-19-2009 06:52 PM
Roof Leaking Bill&Barb smart Operation and Maintenance 58 09-02-2009 11:32 AM
