Shifter box replacement. - Page 4 - Smart Car of America Forums : Smart Car Forum
Old 04-28-2008, 09:11 AM   #31 (permalink)
RussBarnes's Avatar
Now I know why I couldn't take mine apart and following the pliers and cloth directions mine is scarred up - I have the new one and mine is an 11/07 build.....so much for smart using the same parts.....
Old 04-28-2008, 06:57 PM   #32 (permalink)
Would explain my lack of shifter problems. Build date 2/08.
Old 04-29-2008, 08:15 AM   #33 (permalink)
robotbill's Avatar
But my build date was also 2/08, just my luck I got the "old" shifter. This "new" shifter seems to learn faster than the other one.
robotbill is offline   Reply With Quote
Old 05-02-2008, 11:07 AM   #34 (permalink)
From what I can see, I have the new shifter and my car's currently at the shop for sticking in Park. My build was 11/07.
Arizona Smarty is offline   Reply With Quote
Old 05-02-2008, 04:33 PM   #35 (permalink)
robotbill's Avatar
So what we have is a mish mosh of "old" and "new" shifters regardless of what month the car assembled in. I wonder if Evilution has seen this problem on the other side of the pond?
Old 05-02-2008, 06:56 PM   #36 (permalink)
a2jack's Avatar
Either that, or they all start to fail as the miles rack up. I sure hope not, BTW Evo has the Euro box and they have had few problems.
A2Jack.
a2jack is online now   Reply With Quote
Old 05-08-2008, 02:54 PM   #37 (permalink)
The new lower plastic sleve turns counterclockwise an 1/8 th to 1/4 turn. Then you can pull straight up on the knob to remove it. My car would not shift so I pulled the knob and lubed it a bit. Now it works perfect.
See ... DIY gear shift removal and lube (short video)
KeithAlanYerian is offline   Reply With Quote
My gear shifter broke. Andrewlcox smart General Discussion 17 11-19-2008 11:45 AM
windshield replacement willelm smart Operation and Maintenance 8 11-15-2008 10:39 AM
Shifter Locked In Park. Again! a2jack smart Operation and Maintenance 7 05-22-2008 07:03 PM
replacement panels idrivesmart smart fortwo (451 - US vehicle) 2 03-31-2008 08:11 PM
windshield replacement citroen smart Operation and Maintenance 12 02-28-2008 10:56 AM
