Old 08-11-2008, 02:38 PM   #1 (permalink)
Shifter Button Stuck quick-fix = WD-40!
I had my shifter button start to stick over 3 days, finally jamming completely in Park at work, and I tried everything I could to push it in. I tried pliers (wrapped in cloth), I tried hitting it with my fist (painful), I tried pressing a metal rod on it to get leverage. Nothing. Wouldn't budge. Just as I was about to try a tow, I got on the forums and saw it was a lubrication problem. I tried to remove the shifter knob as suggested in a couple of threads here, but no luck. Mine wouldn't turn, even with a wrench (wrapped in cloth). I decided on one last desperate measure - WD-40. I got the straw and sprayed it in the crack between button and shifter knob in a couple of spots. Worked like magic. Instant un-stuck!
I then took the car into the dealers anyway and had the shifter knob replaced just to be safe, since I doubt WD-40 is an approved lubricant, but now I know I won't get stuck again.
hajiii is offline   Reply With Quote
Old 08-11-2008, 04:13 PM   #2 (permalink)
WD-40 isn't really a lube.
Its a water displacement formula. Excellent for corrosion or drying out distributor caps though.
saskdiesel is offline   Reply With Quote
Old 08-11-2008, 04:39 PM   #3 (permalink)
Senior Smartie
jonnysan's Avatar
This topic has been covered at length
In another thread and it is so a lube that happens to also have water displacement qualities as well.
That's all I'm going to say....
Old 08-11-2008, 06:27 PM   #4 (permalink)
Water Displacement Formula Number Forty was originally developed for cleaning the aluminum skin of the Atlas booster rocket.
The base for WD is kerosene, which is not a lubricant. It works as a solvent, but not particularly well.
WD excels at water displacment. Which is why you use it liberally on a wet rifle or shotgun as it evaporates quickly.
Never use it as a gun lube.
Use it on electronics though, as it leaves no residue (or lube).
Old 08-11-2008, 06:39 PM   #5 (permalink)
NCC1701's Avatar
Drive: 2008 smart cabriolet
Y'all debate whether or not WD-40 is a lubricant. But, it appears to have done the trick, at least temporarily, for hajiii. It feels slippery on your fingers. I've used it on squeaky door hinges and sticky locks.
From the WD-40 web site:
WD-40 literally stands for Water Displacement, 40th attempt. That's the name straight out of the lab book used by the chemist who developed WD-40 back in 1953. The chemist, Norm Larsen, was attempting to concoct a formula to prevent corrosion-a task which is done by displacing water. Norm's persistence paid off when he perfected the formula on his 40th try.
While the ingredients in WD-40 are secret, we can tell you what WD-40 does NOT contain. WD-40 does not contain silicone, kerosene, water, wax, graphite, chlorofluorocarbons (CFCs), or any known cancer-causing agents.
WD-40 is the ultimate multi-purpose problem solver. WD-40 cleans/degreases, penetrates to loosen up stuck parts, prevents corrosion and is a light lubricant.
What does WD-40 do?
WD-40 fulfills five basic functions:
1. CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape and excess bonding material.
2. DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
3. PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
4. LUBRICATES: WD-40's lubricating ingredients are widely dispersed and tenaciously held to all moving parts.
5. PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
Old 08-11-2008, 06:43 PM   #6 (permalink)
Please, don't confuse us with the facts.
Old 08-11-2008, 06:52 PM   #7 (permalink)
maxtraxduffy's Avatar
Drive: 2001 ford ranger&08SMART
3&1 Oil Is The Ticket!!!!!!i Keep It In My Clove Box.
maxtraxduffy is offline   Reply With Quote
Old 08-11-2008, 07:09 PM   #8 (permalink)
MikeDCop's Avatar
Drive: 07 F150, 05 HD, 75 Celica
And it works great at cleaning the wrinkled black finish of a Harley engine. Spray it on a cool/warm black Harley engine and watch it evaporate leaving it looking factory new. FYI
MikeDCop is offline   Reply With Quote
Old 08-11-2008, 07:16 PM   #9 (permalink)
You guys could argue that rain is wet.........
Old 08-11-2008, 07:46 PM   #10 (permalink)
When I started working as a mechanic at a GM dealership years ago I was given some advice from some of the olders guys.
"Never let the shop foreman catch you spraying WD-40 on any moving part, you won't make it past your probationary period".
gearshift, knob, park, shifter, stuck
Shifter stuck in park - Here's the get me home fix. a2jack Smart Car Operation and Maintenance 57 01-14-2009 07:06 PM
Gear Knob Button STUCK!! sixcrows Smart Car Operation and Maintenance 67 10-13-2008 01:12 PM
Shifter stuck again babybenz Smart Car Operation and Maintenance 10 06-15-2008 02:16 PM
Broken Rag Top Button rrrucke Smart Car Operation and Maintenance 6 04-15-2008 04:36 AM
