Shifter stuck in park - Here's the get me home fix. - Page 6 - Smart Car of America Forums : Smart Car Forum
LinkBack (6) Thread Tools Display Modes
Old 08-11-2008, 01:41 PM   #51 (permalink)
I dunno' if this is related, but I'll give it a shot...I had an issue with my Toyota Corolla awhile ago where the battery went dead nose in in a parking lot. In order to jump the battery, I had to put the car in neutral, back it out, and pop the hood. But you can't shift the automatic transmission with no battery power (or, for that matter when the brake pedal light switch is broken) unless you remove a little plug and insert a screwdriver into a manual override. Since I want to be prepared, can you shift the smart from park to neutral when the battery is drained, and if not, is there a transmission override? (does that make sense?)
dave104 is offline   Reply With Quote
Old 01-14-2009, 08:35 AM   #52 (permalink)
great video
saved me a tow (really saved them a tow)
the guy at the dealer told me to just pull hard on the shifter and it should come off - RIGHT, not.
i was able to turn it with my hand no need for tape or tools - so i would try that first
It did not seem to need any lube as it shifted great with the little white piece, very easy and smooth. I think the problem is with the button on the shifter but i may be wrong as it seemed to work fine when off also.
there was another at the dealer with the same issue and they told me they have seen a lot with the issue
i got mine in april after a long wait on the list as i signed up the first day it was available - just over 3k miles
toddmitchell is offline   Reply With Quote
Old 01-14-2009, 08:52 AM   #53 (permalink)
Check out post #1 in this thread. That's probably as close as you're going to come to an answer unless you want to disconnect the battery and then try the "get me home fix" to see if it still works.
Old 01-14-2009, 09:32 AM   #54 (permalink)
Originally Posted by toddmitchell View Post
... It did not seem to need any lube as it shifted great with the little white piece, very easy and smooth. I think the problem is with the button on the shifter but i may be wrong as it seemed to work fine when off also. ...
The knob button actuates a plastic sliding cam that depresses the white vertical shaft. Both the face of the cam and the top of the shaft need lubrication. There is little bearing surface between the two plastic pieces for really smooth, long-lasting operation. It would have been better if M-B spent a little more and made the pieces out of machined "oil-bronze" or designed the actuating knob to be on the top, directly depressing the vertical shaft.
Some of my "Emergency Roadside Procedure" cards (laminated 4" x 9" cards printed in large Arial Bold font for low-light use, and kept in the glovebox):
Old 01-14-2009, 09:54 AM   #55 (permalink)
re: #54 Old smart
Your 'Emergency Procedure Cards' are a GREAT idea !!
Can you post the .doc files or .pdf so we all can use them?
tnx...
phillysmart is offline   Reply With Quote
Old 01-14-2009, 10:51 AM   #56 (permalink)
Originally Posted by phillysmart View Post
re: #54 Old smart
tnx...
Can't do it as Word .doc files (too big). I'll try as .txt. (sans photos):
Attachment 646
Attachment 647
Attachment 648 (photo with yellow markers missing in file)
Missing photo:
(a2jack)
Old 01-14-2009, 10:53 AM   #57 (permalink)
re: #54 Old smart
tnx...
Last one:
Attachment 649
You should be able to massage the .txt files back into Word format with the proper font.
Old 01-14-2009, 07:06 PM   #58 (permalink)
SmartDigger's Avatar
I thought this was a thing of the past.
Old 01-04-2010, 10:01 AM   #59 (permalink)
Mad about smarts and Cats
BB Benz's Avatar
Missing links
Last one:
Attachment 649
This is something I would like to have! Too bad these links are no longer valid!
Old 07-23-2010, 10:37 PM   #60 (permalink)
This looks like something I need to investigate more closely as I am having the same issue...
Crossblade is offline   Reply With Quote
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/shifter-stuck-park-heres-get-me-home-fix-5578/
Shifter Locks When Brake Light Switch Fails ! - smart USA insider This thread Refback 10-21-2008 09:27 PM
Morning Surprise - smart USA insider This thread Refback 10-10-2008 08:59 AM
(not so smart) parking - smart USA insider This thread Refback 09-05-2008 09:33 PM
Shifter Locks When Brake Light Switch Fails ! - smart USA insider This thread Refback 07-02-2008 06:25 PM
Shifter Locks When Brake Light Switch Fails ! - smart USA insider This thread Refback 07-02-2008 12:54 PM
Shifter Locks When Brake Light Switch Fails ! - smart USA insider This thread Refback 07-02-2008 12:46 PM
Shifter Locked In Park. Again! a2jack smart Operation and Maintenance 7 05-22-2008 07:03 PM
Key is stuck in Ignition Bob_Parr smart Operation and Maintenance 48 05-08-2008 02:55 PM
Stuck in Denver dakotastan smart General Discussion 3 03-30-2008 03:09 PM
My roofs locked and stuck down mybabyjackblack New Members Area 1 02-09-2008 12:29 PM
Transmission Shifter: P = Park or not? kmeinhold smart General Discussion 4 12-12-2007 09:14 PM
