Originally Posted by fpage77
 It's literally on the edge of the tread before the sidewall. They did that tar stick plug thingy with the weird screwdriver. Old smart says I need repair done differently and I'm never heard of plugging holes with mushrooms before.
That is the correct way to repair a puncture in a tire. The tire will have to be re-balanced after this method of repair but it really is the only 100% reliable way to do a long term repair.
The plug is inserted from the inside and the term mushroom is used because the plug resembles a mushroom in appearance. They reach thru the puncture with the insertion tool from the outside in, attach it to the mushroom that already has the "goop" on it (sealant/adhesive) the then the mushroom "head" is pulled up against the inside surface of the tire, mushroom stem facing outward. Then the stem is shaved off flush with the tire tread and away you go.
VERY reliable method and it has worked successfully for decades...
