Old 05-09-2009, 08:44 PM   #1 (permalink)
SmartDigger's Avatar
Drive: 09 cabriolet
side turn marker
The other thread got the cat in me. I was going to unhook the bulb in the side marker to see if it flashed fast. Here is where the cat got killed, I could not figure out how to get it off. is it the same as the 450 side marker at Evilution.
Old 05-09-2009, 10:11 PM   #2 (permalink)
Mom liked you better...
The Rigger's Avatar
Drive: '09 Smart Passion Cabrio
Look at Evilution under "removing front panels," filtered down to "new 451," and you'll see where you pop out the side repeater/marker lights. You'll have to reach behind the front arches to release the clips, so you'll have to at least remove the top triangles, the two Torx bolts per side (and the metal sleeve/spacer) on top, and the panel fastener in the door jamb to loosen it up enough to get your hand back in there. You may even wind up removing the side skirts and pulling the T25 Torx at the bottom of the panel, too.
Old 05-10-2009, 03:24 AM   #3 (permalink)
Haven't tried this so no guarantee: FQ101 : Taking Modification to the Next Level
It shows no panel removal at all.
Old 05-10-2009, 08:14 AM   #4 (permalink)
JOIN SCOA..YOU'LL BE GLAD
Drive: modified 65 stang conv
...jwight..that's the one that worked for me..
jetfuel
Old 05-10-2009, 07:21 PM   #5 (permalink)
Drive: 09 cabriolet
Thanks, I'll try this tomarrow.
Old 05-11-2009, 11:20 AM   #6 (permalink)
Red Roller Skate
fpage77's Avatar
Drive: '09 passion coupe
Go take the cat out of you then.
Old 05-11-2009, 11:27 AM   #7 (permalink)
Don't feed the Panda
Drive: 09 Red/Blk/Blk Passion
jetfuel
Me too
Works just like the license plate lights
Grey & Silver Side By Side And The 2009 Red Alan From New York Smart Car General Discussion 8 01-03-2009 04:42 PM
PICS new red old red side by side babybenz Smart Car General Discussion 24 12-10-2008 08:35 PM
behind the turn signal bar... letsgoskatepool Smart Car General Discussion 3 06-23-2008 09:53 AM
Radio won't turn off jerryd New Members Area 11 05-21-2008 04:19 PM
