Slow to warm up - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 01-30-2009, 10:05 AM   #11 (permalink)
SylenThunder's Avatar
Also, don't set it to recirculate. I don't understand why... but after a minute on recirculate the air coming from the vents gets damp, this makes the windows fog up really quick. Haven't figured out why this happens.
Old 01-30-2009, 12:19 PM   #12 (permalink)
Originally Posted by SylenThunder View Post
If you think about it... the engine is in the back.... the radiator/heating coil is in the front. Long process to get the hot water from the radiator piped all the way to the front of the car, and since it is especially cold out, it is cooling off before it even hits the radiator, much less the heater coil to heat the inside of the car.
All I can say is, "Thank _____ for heated seats!"
Just realized the problem with this explanation - if the engine is cold the thermostat should be closed and no water circulating from the engine to the radiator. As suggested maybe worth having the thrmostat checked incase MB engineered some trick electronic thingy which doesn't work
GordonD is offline   Reply With Quote
Old 01-30-2009, 12:29 PM   #13 (permalink)
Mom liked you better
The Rigger's Avatar
Because instead of drawing in any fresh outside air, you're recirculating the cabin air, which includes all the expelled CO2 and water vapor from your breath.
Recirculating's okay for A/C in the summer, but not such a good idea for defrosting/defogging in the winter.
Old 01-30-2009, 12:41 PM   #14 (permalink)
That is what I had originally thought.. but it goes from being fine, to sauna in a matter of seconds. It's almost like I poured a pucket of water onto the heater coil. Flipping a switch fast. Sometimes it takes a minute or two longer to happen... but it goes from fine and dry inside to rainforest in about 3-5 seconds. I have considered taking it to have it looked at at the dealer but haven't had time yet.
Old 01-30-2009, 02:38 PM   #15 (permalink)
Definitely sounds like a "dealer" trip to me
It's MORE than just the "recirc"
Old 01-30-2009, 06:36 PM   #16 (permalink)
Maybe the same mechanism that caused some cabin air filters to grow mold... from excess moisture during the summer.
Someone had suggested closing the vents by activating recirc just before shutdown. Maybe that will help?
Old 01-30-2009, 08:52 PM   #17 (permalink)
From my experience, that's definitely not normal. If I put recirculation on BEFORE the car has warmed up I get fogging (but definitely no sauna or rainforest.) AFTER the car warms up a bit, I hit recirculation to warm up the cabin faster. It does warm up faster and, I think, more evenly, and the windows don't fog.
Hard start with warm engine. smartie1 smart General Discussion 3 08-13-2009 07:41 AM
New HD Camera with Slow Motion.... BobDiaz Tech & Gadgets 19 01-31-2009 02:37 PM
Slow to Accelerate from Stop SmartAnita smart Operation and Maintenance 7 04-18-2008 03:48 PM
smart warm up time? sbernali smart General Discussion 10 04-05-2008 07:51 AM
