smart jacking - Smart Car of America Forums : Smart Car Forum
Old 03-03-2008, 11:49 AM   #1 (permalink)
smart jacking
Has anyone jacked up there car with an on bord type of jack yet.
Thanks karl
Old 03-03-2008, 12:10 PM   #2 (permalink)
BandSofC's Avatar
I'd just like to know the recommended jacking points for a standard floor jack. Did I miss it in my manual? Are there jacking points? Is a tire service center (for example) going to have a clue how to put it on a lift?
BandSofC is offline   Reply With Quote
Old 03-03-2008, 06:59 PM   #3 (permalink)
bumblebee's Avatar
I've tried to jack up my smart but I am having difficulty trying to leave it on jack stands. There are triangles marked on the plastic molding underneath the car telling you where to jack. That part was easy. Use a floor jack and the car lifts up. However, I am stumped as how to put the car on jack stand as there's really no room to work with once you put the floor jack to jack it up properly. DO NOT TRY TO LIFT IT TO EITHER SIDE OF THE TRIANGLE. I tried to lift the car up with the floor jack just a few inches away from the triangle and it didn't take long to hear a loud pop from the plastic panel under the car to snap. The plastic piece is bend a little and I think that's the only damage there is. I wanted to take the wheels out and take them for a powder coating. Now I'm gonna to wait until someone figures out how to put it on jack stands properly.
Oh and I've search the manual and it did not tell you anywhere to jack up the car.
bumblebee is offline   Reply With Quote
Old 03-03-2008, 07:40 PM   #4 (permalink)
Whoops. I thought you guys were talking about someone taking the car at gunpoint.
Old 03-03-2008, 07:43 PM   #5 (permalink)
shack01's Avatar
How about getting two 2x4s cut to the length between the triangles on each side. use a floor jack to raise up the entire side and slide a jack stand under each end of the 2x4. Repeat for the other side. Works like a champ on the MINI.
tm
shack01 is offline   Reply With Quote
Old 03-03-2008, 11:09 PM   #6 (permalink)
I found a front point nothing at the side/rear the 450 had distinct points this has me thinking about fabricating something to replace the saddle in a floor jack. karl
has anyone done this with something you would carry in the car
Old 03-04-2008, 09:11 AM   #7 (permalink)
doc540's Avatar
Lift Points?
Not sure if this helps, but it's relevant discussion.
doc540 is offline   Reply With Quote
Old 03-04-2008, 09:20 AM   #8 (permalink)
Originally Posted by doc540 View Post
Lift Points?
that is a 450 not the same unfortunately
Old 03-05-2008, 08:02 AM   #9 (permalink)
nobody ?
Lots of folks posted about buying spare wheels and tires...
Old 03-05-2008, 08:44 AM   #10 (permalink)
smart Jacking
My inclination would be to not buy a trolley jack and jack stands, but buy four hydraulic bottle jacks instead. Light duty ones are not that expensive.
