Old 05-08-2009, 08:13 PM   #11 (permalink)
Drive: '95 SAAB 9000 CSE
P0455
Normally, a gas cap, for sure. It will still cost you $$$ at a shop. To be sure of course this could be a result of a damaged(open)line in your evap system.
Smart Magus
Smart Magus is offline   Reply With Quote
Old 06-17-2009, 11:21 AM   #12 (permalink)
Found this one on smartusainsider.com:
P0336 "Crankshaft Position Sensor A CKT Range/Perf" Easy to spot - the car dies. Fixed under warranty.
Old 06-17-2009, 11:37 AM   #13 (permalink)
Drive: Merlot Red Cabriolet
I'm not sure of the absolute source but there may be other information here:
http://scp-parts.com/pdf/obd2.xls
Old 06-17-2009, 11:47 AM   #14 (permalink)
May be the same one Jim added in post #6.
Old 07-17-2009, 09:51 AM   #15 (permalink)
Thanks dude for nice infos....
loknath is offline   Reply With Quote
Old 07-17-2009, 02:03 PM   #16 (permalink)
Drive: smart passion, Dodge carav
PO072 showed up on my scangauge after airco quit, no outside temp, check engine light. Turned out to be loose instrument cluster connection after cruise control install. PO072 not on Evilution list.
Louis
louis bolieu is offline   Reply With Quote
Old 07-17-2009, 02:57 PM   #17 (permalink)
Drive: Cabrio 2008!
Louis
The sheet I have indicates P0072 is not related to the instrument cluster. It's listed as:
Exhaust Valve Control solenoid Circuit Range/Performance Bank 1
Old 07-17-2009, 03:12 PM   #18 (permalink)
Curious; the most common definition I can find (doesn't mean it's right) is: P0072 Ambient Air Temperature Sensor Circuit Low Input
Another list shows the P0xxx codes as generic powertrain items.
Old 08-18-2009, 08:15 AM   #19 (permalink)
NY Smartie's Avatar
Drive: '08 Coupe Silver/Blk/Blk
Originally Posted by JimDantin View Post
If you'd like all of the codes in a single file, I compiled this.
http://personalpages.bellsouth.net/j...lt%20Codes.xls
that was very helpful, thanks!!!!
Old 09-28-2009, 03:02 PM   #20 (permalink)
P1800 & P2802 OBD II codes
From another thread, these are transmission related:
P1800 Transmission Clutch Interlock Safety Switch Circuit Failure
P2802 Transmission Range Sensor B Circuit Low Input
Code 24 rpcrichton Smart Car Operation and Maintenance 2 11-19-2008 03:10 PM
Fraudulent eBay Listings (1) sheureka Smart Vehicle Marketplace 10 09-03-2008 11:19 AM
Many ebay listings Karinann Smart Car General Discussion 1 07-17-2008 09:35 AM
New 450 parts and accessory listings.. smartcarparts Dealers and Parts 0 05-29-2008 02:52 PM
reservation code smart1 Smart Car News & Rumors 50 10-26-2007 08:37 AM
