Smart wont start security code issue - Smart Car of America Forums : Smart Car Forum
Old 04-27-2009, 04:32 PM   #1 (permalink)
Help!! My Key battery went dead and when I replaced it and try to open the door the lights just flash 9 times. The car wont start as it obviously is in some type of security mode. Can anyone tell me how to reset it?
fastsmartcar is offline   Reply With Quote
Old 04-27-2009, 04:54 PM   #2 (permalink)
Admin/Mod.
Are you sure you have the battery's polarity right (+/-)? Just a thought.
Old 04-27-2009, 04:56 PM   #3 (permalink)
battery is perfect
but I thought about disconnecting it for a bit to see if the car resets
Old 04-27-2009, 05:01 PM   #4 (permalink)
What year? try another new battery in the remote, or disconect the battery under the carpet on right side for a few minutes,or 2nd key if you have one! or to the dealer if its an 08 or 09 if the new battery trick don't do it..
smart2 is offline   Reply With Quote
Old 04-27-2009, 05:03 PM   #5 (permalink)
thanks...I did all that...my dealer cant figure it out...duh!!!
Old 04-27-2009, 05:23 PM   #6 (permalink)
Admin/Mod.
Did you check the second fob?
Because, if a fob is pocket or purse held and the buttons are pressed inadvertently and repeatedly, the code will eventually get lost. After 128 or 256 unconnected press (that's without a handshake with the car), the code is lost and the fob requires to be reprogrammed. At least that's what was posted sometime last year...
But again, you say that your Dealer is clueless.
Old 04-27-2009, 05:43 PM   #7 (permalink)
Yes, my dealer (who is a large Smart Dealer) has never encountered this particular problem and he is unable to get my car started.
Old 04-27-2009, 05:44 PM   #8 (permalink)
the second fob does the same thing...I'm hoping someone can explain how to reprogram or who to contact to do it....
Old 04-27-2009, 05:50 PM   #9 (permalink)
The owners manual says that's the sign of a bad key fob battery; any chance the replacements used are bad also?
Old 04-27-2009, 06:11 PM   #10 (permalink)
Nope, I bought several batteries and tried them all...then tested them at Radio Shack...but thank you for the suggestion. I can read where others have had a similar problem in the forum discussions, but I have not seen anyone have a solution...
Convertible top wont go up??? artistalana smart Operation and Maintenance 10 05-14-2011 12:18 AM
Aftermarket security systems cambridgecommie smart General Discussion 0 03-19-2009 03:49 PM
Awesome SMART security system Carl242 Off-Topic Cafe 3 06-15-2008 11:22 AM
Radio 10 security code? Fredvon4 smart Operation and Maintenance 15 05-23-2008 06:39 AM
Air Farce One: new smart car security system spdickey smart Videos 13 11-08-2007 05:26 AM
