Strange intermittent noise from front of car - Smart Car of America Forums : Smart Car Forum
It's alive...!
Old 01-10-2012, 06:20 PM   #1 (permalink)
I have a 2008 Passion with 64,000 miles and two weeks ago it started to make a noise from the front of the car - sometimes. The noise sounds like a horn noise, but it's not as loud as my horn. Sometimes it does it a number of times in a 5 mile drive and sometimes it does not do it at all. Since my first month of ownership I've had no problems with my smart. Any thoughts?
artist is offline   Reply With Quote
Old 01-10-2012, 07:20 PM   #2 (permalink)
SmartDigger's Avatar
I would check the wire to the horn for a short.
Old 01-10-2012, 07:20 PM   #3 (permalink)
NCC1701's Avatar
There was a similar thread not long ago. Not sure anyone came up with a definite answer. Mine's a 2008 too. I'd be interested in knowing what it is.
Old 01-10-2012, 07:30 PM   #4 (permalink)
smark's Avatar
Front brake pads, are singing. They will make a faint noise, after a couple mile driving. They heat up, and start to sing. Like a weak horn, or cell phone noise. Just replace them. No more noise. If you want to test the issue. Drive the car on the highway around 60-70. When you hear the noise. Step on the brake. If the noise goes away. Its you pads singing.
The Following User Says Thank You to smark For This Useful Post:
artist (01-11-2012)
Old 01-15-2012, 01:42 PM   #5 (permalink)
astuto's Avatar
I also have a strange noise up front. I first noticed it a few months ago, only when I was following close behind a truck at 60+. It would stop when I changed lanes. Then it would occur anytime I followed a car or truck close. Yesterday I heard it even when I wasn't following anything. It is the same noise my old Mirage would do when it needed oil. Yes, I've checked the oil and have recently had an oil change. It's sort of a knocking noise.
astuto is offline   Reply With Quote
Old 01-15-2012, 02:03 PM   #6 (permalink)
I'd check for loose body panels. The first points I'd check are the clips at the bottom of the front panel (below the radiator) and the service flap (really easy to put the service flap in wrong).
... you really need to check the oil more often if you know it's leaking like that... how long did that Mirage last... ?
deepblueQ is offline   Reply With Quote
Old 01-15-2012, 03:00 PM   #7 (permalink)
smark's Avatar
Change your brake pads!
Old 01-15-2012, 04:23 PM   #8 (permalink)
Mad about smarts and Cats
BB Benz's Avatar
Air turbulence when following other vehicles, even on a wind free day can cause the gas flap to clatter against the body. That noise can be difficult to track down. I thought for the longest time it was the cabrio top flapping.
Old 01-15-2012, 04:30 PM   #9 (permalink)
Lifetime Member
Kermit's Avatar
The one you are thinking of..........this it?
HELP! Odd sound occurring. (sway bar end link)
Old 01-15-2012, 05:48 PM   #10 (permalink)
astuto's Avatar
... you really need to check the oil more often if you know it's leaking like that... how long did that Mirage last... ?[/QUOTE]
Had the mirage for 10 years and over 200,000 miles when I bought my 08 SMART. Kept it a few more years as a second car, but hardly used it so I sold it last year.
Newbie: Strange Bolt on Front Caliper (06 diesel) kartwood Modifications and Repairs 5 04-19-2013 07:18 PM
Strange Noise - Help Needed (purge valve?) ehaughn smart Operation and Maintenance 19 12-09-2011 09:24 PM
Front end noise at speeds? smartiebenz rugg smart General Discussion 12 11-02-2011 08:22 AM
Intermittent wiper NOISE? tivoboy smart Operation and Maintenance 1 01-27-2010 10:49 AM
Strange knocking noise dink74 smart Modifications 25 06-07-2009 02:14 PM
