Stuck in Park - Smart Car of America Forums : Smart Car Forum
Old 12-03-2008, 11:01 AM   #1 (permalink)
Stuck in Park
As many of you know, my smart car had a deer strike. In a few days it will be towed to the body shop. Currently, there is no power to the car. The adjuster had to disconnect some wiring harness. No power, unable to shift out of park, can't unlock the steering wheel. The adjuster doesn't recommend hooking anything back up. This means that the car is stuck in park and it needs to be in N for towing. Is there anywhere over ride this, other than have to reapply power to the car?
Bch Smart is offline   Reply With Quote
Old 12-03-2008, 11:03 AM   #2 (permalink)
Shifter Stuck in Park, here is the get home now fix
Shifter stuck in park - Here's the get me home fix. This mignt work!!
Old 12-04-2008, 05:00 AM   #3 (permalink)
nprsmart's Avatar
When my car had to be towed to the dealer, they just pulled it up on a big tilting flat bed truck. The locked (with parking brake applied) rear wheels just skidded up the truck bed.
nprsmart is offline   Reply With Quote
Old 12-04-2008, 05:31 AM   #4 (permalink)
Admin/Mod.
Originally Posted by nprsmart View Post
... rear wheels just skidded up the truck bed.
Ouch! Sounds mechanically incorrect. Any other way?
Old 12-04-2008, 05:48 AM   #5 (permalink)
... The adjuster had to disconnect some wiring harness. ...
Why did the adjuster (take it upon himself to) disconnect some wiring harness? Is the underwriter going cover any problems or expense the adjuster may have caused?
Are you going to have the bodywork done at Checkered Flag's shop?
Old 12-04-2008, 07:44 AM   #6 (permalink)
To prevent the airbag deployment while he was poking around.
Yes
Yes. Squirk heads to the body shop on Monday.
Shifter stuck in park - Here's the get me home fix. a2jack smart Operation and Maintenance 65 12-07-2011 11:00 AM
Stuck in park abs and solid ! light T12121 smart Operation and Maintenance 13 10-15-2008 01:17 PM
Perfect place to park... in the park perzbenz smart Gallery 1 08-19-2008 05:41 PM
Car stuck in Park - Dealer says out of GAS!!! forumware smart General Discussion 6 08-06-2008 07:09 PM
Key is stuck in Ignition Bob_Parr smart Operation and Maintenance 48 05-08-2008 02:55 PM
