Timming Belt/Chain and Water Pump on Smart - Smart Car Forums
post #1 of 10 (permalink) Old 08-19-2010, 11:13 AM Thread Starter
Smartmadness.com
2micro4u's Avatar
Quoted: 1 Post(s)
When is the Timming Belt or Timming Chain / Water pump due to be replaced? At how many miles?
2micro4u is offline
post #2 of 10 (permalink) Old 08-19-2010, 11:37 AM
banned
Theoretically 60k... I had smart center Sarasota look at it at 66k and I had to force them to do it... it was still in good condition.
Wdhitch is offline
post #3 of 10 (permalink) Old 08-19-2010, 04:54 PM Thread Starter
Smartmadness.com
2micro4u's Avatar
Quoted: 1 Post(s)
Thanks
2micro4u is offline
post #4 of 10 (permalink) Old 08-19-2010, 06:41 PM
Lifetime Member
Kermit's Avatar
Quoted: 6 Post(s)
No Wdhitch. He said Timing Belt/Chain.
It's got a chain Micro, haven't a clue when it wears beyond use. I could have sworn I have heard from a reputable source around 150k-200k but DO NOT quote me on it. I would suspect the water pump is right around the same.
Kermit is offline
post #5 of 10 (permalink) Old 08-19-2010, 08:05 PM
SmartDigger's Avatar
Quoted: 167 Post(s)
I would say when the old one breaks. Preventative I would say 100-150K
SmartDigger is offline
post #6 of 10 (permalink) Old 08-19-2010, 10:51 PM
Normally, a timing chain does not have a catastrophic failure like a belt breaking. It simply stretches over time (hours of running) until either the tensioner can't keep it tight or the crank to cam timing shifts enough to affect the performance of the motor. There should be no periodic replacement of the chain. I once replaced a timing chain on a Saab I owned that had 270,000 miles on it. The slack in the chain was causing the ignition timing to float causing rough idle. Nothing was actually broken but I replaced it to get the motor back to optimal running condition. I sold the car later with somewhere around 295,000 on the clock and the motor was still running like a fine timepiece.
HarleyPat is offline
post #7 of 10 (permalink) Old 08-19-2010, 10:53 PM
Oh, and a water pump gets replaced when it starts leaking. Or, in rare cases, if the coolant gets dirty and causes excessive wear of the pump's vane reducing the coolant flow which can lead to overheating.
post #8 of 10 (permalink) Old 08-20-2010, 07:41 AM
Mike T's Avatar
Quoted: 191 Post(s)
On the smarts with the 599/698 and 799 cc engines, the plastic chain tensioners can break, the chains can then jump the cog and all sorts of fun ensues. The oil pump chain is especially one to be wary of. Not sure about the Mitsu engine.
Mike T is offline
post #9 of 10 (permalink) Old 08-20-2010, 04:41 PM Thread Starter
Smartmadness.com
2micro4u's Avatar
Quoted: 1 Post(s)
Thanks every one is very informative. Im glad the smart has a timming chain vs timming belt..Amen 2 that..
2micro4u is offline
post #10 of 10 (permalink) Old 08-20-2010, 06:26 PM
Lifetime Member
Kermit's Avatar
Quoted: 6 Post(s)
I've had two cars of mine jump a tooth on the chain (both 289 Fords). Both because they were stretched.
I am currently working on an Escort with 197k and the water pump IMO was due for a change as the bearing was having some play - a whooping $16 and I swapped it out.
Kermit is offline
Human Verification
331
Timing Belt or Chain? mikie smart fortwo (451 - US vehicle) 7 12-14-2015 10:35 AM
Water pump psi and gph anyone know? GiantKiller smart Operation and Maintenance 5 04-17-2010 07:27 PM
smart Key Chain pattiknutson Pacific NorthWest Region 4 04-10-2010 03:54 PM
Can Tire Kit Pump be used only as a Pump? ulflyer smart Operation and Maintenance 5 03-22-2010 06:38 AM
Smart Air Pump SmartJoeMN Archive/obsolete (?) threads 11 12-10-2009 06:41 PM
