Tire Pressure Monitor light came on - Page 3 - Smart Car of America Forums : Smart Car Forum
Trailer
Old 10-15-2009, 10:16 PM   #21 (permalink)
i have had a small leak now for about 2 weeks
i have put the car in neutral and rolled it back in the driveway (dont worry its completely flat i wont get killed) and have found not a single thing besides very smal stones in the treads
no stuff in the side wall no screws or nails but it still comes on and i fill it back up i think the schrader valve or the tpms is leaking but haven't had a chance to check that yet
rexxxlo is offline   Reply With Quote
Old 10-16-2009, 05:06 AM   #22 (permalink)
The Super Shoe
mdfortwoguy's Avatar
They tend to be overly sensitive in winter. Remember - as it is getting colder out, the pressure in your tires is going to decrease naturally. Mine has been coming on at random for about a week now (pressures are all in spec - I think the difference between a cold tire that has sat all night and one that has been driven on is confusing it).
Old 10-16-2009, 06:10 AM   #23 (permalink)
Tires will loose air over time. Colder weather will affect the sealing on the bead and can make them loose a little more. Aluminum is a very porous metal and can leak air at times too. That is one of the reasons they started clear coating the Aluminum rims, and to prevent them from corroding.
Since we ALL check our tires weekly, it really shouldn't be an issue now should it????
Old 10-16-2009, 07:04 AM   #24 (permalink)
One tire problem I had was a loose valve stem causing me to lose air without punctures.
Old 10-16-2009, 07:09 AM   #25 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...I'm a member of the "Nitrogen Filled Church"...
jetfuel...let's not go there...just me
Old 10-16-2009, 09:38 AM   #26 (permalink)
I wouldn't want to worship there unless the sermons are extremely short and there's no singing.
Old 10-16-2009, 10:23 AM   #27 (permalink)
...they are John!...
...now ...for a good time the Helium Church Choir is a blast...
jetfuel...just praying
Old 10-16-2009, 12:23 PM   #28 (permalink)
fastturb's Avatar
did you use soapy water to check for leaks?
Old 10-16-2009, 09:20 PM   #29 (permalink)
SmartDigger's Avatar
Put some dish soap mixed with water on the tire. put it in a spray bottle. the leak will bubble up the soap.
Old 10-17-2009, 10:28 AM   #30 (permalink)
Mine came on last week. All 4 tires were 10 lbs under. I'm figuring the culprit is the spray I use to clean the wheels. Maybe some overspray got between the tire and the rim and created a slow leak. And thank got for that sticker on the driver side door. I was on hands and knees looking all over the tire for the PSI info.
OCMike is offline   Reply With Quote
Tire Pressure light parrothead smart General Discussion 11 05-18-2009 02:45 PM
Tire pressure warning light is ON doogster smart Operation and Maintenance 2 04-20-2009 07:27 AM
Tire Pressure Warning Light Krootie smart General Discussion 4 04-19-2009 06:16 PM
Tire Pressure Warning Light cpx32 smart General Discussion 23 12-19-2008 04:30 PM
So my tire pressure light went on this morning.... bottlerocket smart General Discussion 2 05-01-2008 05:54 PM
