Tire pressure monitoring ??? - Smart Car of America Forums : Smart Car Forum
Old 09-29-2009, 09:25 AM   #1 (permalink)
Quagmire's Avatar
I'm going to get winter tires and was wondering if there is any problems related to not using tire pressure monitors. I realize that I will have the dash light on. I regularly check my tires and have never relied on tire monitors before.
Old 09-29-2009, 09:28 AM   #2 (permalink)
Padawan's Avatar
No problems, just the little orange light on the instrument cluster.
Old 09-29-2009, 05:16 PM   #3 (permalink)
Padawan is correct. I had my "snows" on all last winter without the pressure sensors. When I put the regular ones back on, I kind of missed the dash warning light.
Old 09-29-2009, 05:33 PM   #4 (permalink)
Padawan's Avatar
I think of it more as the, Don't worry about winter weather, you have your Blizzaks installed! light.
Old 09-30-2009, 10:08 AM   #5 (permalink)
Quagmire's Avatar
Thanks guys.... Going to run with the "Blizzaks on" light.
BTW how are the Blizzaks?
Old 09-30-2009, 10:18 AM   #6 (permalink)
Padawan's Avatar
They're terrific. I never had even the slightest problem in the cold, snow, and ice last winter.
Old 09-30-2009, 10:24 AM   #7 (permalink)
wrumbarger's Avatar
Turn Tire Pressure light off?
UM, I could be wrong (it has happened before)
But, if you install rims that do not have pressure sensors.
And your dash pressure light comes on.
Then push the RESET sensor button on the dash, wouldn't that turn off the dash light? (basically resetting it to nothing)?
Old 09-30-2009, 10:32 AM   #8 (permalink)
smart fortimo's Avatar
I ran the OE tires all last winter through ice and snow and cold down to 0*F. No problems, but the tread was fresh. I relied on them everyday while the AWD sat all winter unused during a rather nasty winter.
But I've got about 25K on those tires now, so this winter I'll be running the Blizzak WS-60's in a staggered config close to OE sizes (front is a 145 vs 155). Along with new wheels, I also added the TPM's.
I'll remember the Blizzaks being on-- not by the TPMS light-- but my aching knees and back After I switch them when the weather gets colder...
Old 09-30-2009, 10:45 AM   #9 (permalink)
Padawan's Avatar
No, because the sensors will not be transmitting back to the on-board receiver. If they're missing, the light goes on regardless of whether you've "reset" the system.
Old 09-30-2009, 10:46 AM   #10 (permalink)
P. 192 in the manual - the light flashes for 60 seconds and then stays illuminated when there's something wrong with the system (such as no signal from the non-existent tire pressure sensors.)
Slow Leak in Tire Pressure When Cold --Not Tire jnonny smart General Discussion 18 03-16-2010 05:48 PM
Tire Pressure Sensors iconpyro smart Wheels & Tires 34 05-21-2009 06:43 PM
Tire Pressure light parrothead smart General Discussion 11 05-18-2009 02:45 PM
Tire pressure way off smart-er Carolinas Chapter 7 10-25-2008 08:48 AM
tire pressure low - fix and warranty aslusers smart General Discussion 9 08-09-2008 07:39 PM
