Tire Wear - Smart Car of America Forums : Smart Car Forum
Old 01-14-2009, 11:56 PM   #1 (permalink)
Tire Wear
I commute in the mountains on windy, hilly, roads. I've noticed uneven wear on the front tires. Both my FourTwo's are wearing heavy from the inside of the front tires.
Is this an alignment problem? Is this a terrain issue? As it stands, I don't expect more that 20K miles unless I reverse the front tires on the rims.
Anyone else see this?
Bryan
bware is offline   Reply With Quote
Old 01-15-2009, 12:02 AM   #2 (permalink)
Been smart for 3.59 years
NCC1701's Avatar
I'm not qualified to answer you. But, I saw from your introduction that you're driving 450s. That might be relevant, or not. But, I think you should mention that fact when you're asking members for information.
Old 01-15-2009, 01:57 AM   #3 (permalink)
Drive: Pulse
Bryan
Get your alignment checked. This is not normal.
Old 01-15-2009, 08:00 PM   #4 (permalink)
eqwalker's Avatar
Bryan
I fully understand what you are saying. I have 24k miles on mine and the front tires are wearing very noticeably on the insides of the tires. I plan to have the alignment checked when I replace the tires within a couple of thousand miles (if they will last that long). They must be out of alignment.
Old 01-15-2009, 08:21 PM   #5 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...don't wait too long to check it....if indeed is a toe or camber issue the extra stress put on the steering system will damage bearings, rod ends and ball joints...my 1c
jetfuel...join SCOA...you'll be glad you did
Old 01-16-2009, 11:07 AM   #6 (permalink)
a2jack's Avatar
Tire damage is just now starting to pop up on a few 08 451's ours included... Read this thread. A2jack.
Almost Too Late at 20k !
a2jack is online now   Reply With Quote
Old 01-17-2009, 01:39 AM   #7 (permalink)
ExonicJay's Avatar
Talked to a guy last week that has two Smarts.
Both were having uneven tire were at 6,000 miles.
He had an alignment shop check the alignment.
The shop told Him there is no way to adjust the camber on His Smarts.
The camber is fixed at the factory.
Toe-in is the only adjustable that can be made.
Can anyone confirm this?
BTW: The toe-in was way out of alignment causing the uneven tire wear on both cars.
ExonicJay is offline   Reply With Quote
Old 01-17-2009, 03:24 AM   #8 (permalink)
Correct - toe only, not camber. Mis-adjusted toe can cause wear; camber has no effect on wear.
Old 01-17-2009, 06:39 AM   #9 (permalink)
Padawan's Avatar
I wouldn't go so far as to say camber has NO effect on wear, but toe is certainly a much more direct influence.
Old 01-17-2009, 06:42 AM   #10 (permalink)
Padawan's Avatar
By the way, I definitely encourage everyone to have their alignment checked. I had been experiencing a slight wandering on the highway and a steering wheel that was a bit off centre ever since I took delivery of All Ball. Expecting it to be a simple issue, I took it in to the dealer and this was the result.
Some surprising (and upsetting) news today...
tire troubles
Flat Tire Fix MaryG smart Operation and Maintenance 17 01-16-2009 04:24 PM
Tire roar eqwalker smart Wheels & Tires 54 01-05-2009 11:25 AM
One 175-55-16 Tire jonnysan Archive/obsolete (?) threads 4 11-10-2008 11:07 AM
Front tire and rim foyfarlow smart Wheels & Tires 7 10-29-2008 05:26 PM
leather wear retiltxet smart General Discussion 17 09-30-2008 05:07 PM
