Tire Wear - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 01-17-2009, 12:12 PM   #11 (permalink)
JOIN SCOA.YOU'LL BE GLAD
camber has no effect on wear.
...sorry could not help myself...but...this type of misinformation is not healthy in a tech site...
jetfuel
Old 01-20-2009, 11:48 AM   #12 (permalink)
eqwalker's Avatar
Is it just my lack of knowing about wheel alignment, or is it just ridiculous that there is not any camber adjustment?? I thought that all vehicles should be able to have wheel camber adjusted. I know that on Corvettes when the rear tires squat that is a sure sign that you need an alignment on the rear wheels (camber adjustment), or suspension parts replaced for it is not normal. I've noticed the smart squatting as well (as I have seen on about all of them) and also am seeing that my rear wheels are now showing "rounding" of the inside of the rear tires due to it. I was intending to have the shop adjust the camber on them when I put a new set of tires on so as not to prematurely wear them too. Comments?
Old 01-20-2009, 12:00 PM   #13 (permalink)
Quagmire's Avatar
Just a thought... As our cars are much narrower than the average car, does it stand to reason that we are experiencing odd tire wear because our cars don't always fit in the "tracked" area of the road? If travelling on a road heavily used by trucks, this becomes more evident.
Old 01-20-2009, 06:47 PM   #14 (permalink)
SmartDigger's Avatar
The car is designed to have the camber like it is.
Old 01-20-2009, 07:13 PM   #15 (permalink)
Drive: Pulse
The rear camber on the smart does not change as the suspension ages. Nor does it "squat" from its fixed point when the car is loaded. Therefor, there is no need to adjust the camber.
It is set during construction at the factory and, like SmartDigger says, is designed into the suspension geometry by the car's engineers.
Oh... and P.S. yes, it affects tire wear. The rear rubber will wear out before the front. The tread wear difference on mine is about 10,000km - 6,000mi
2005 Pulse @ 70,000km - 42,000mi
Old 01-20-2009, 07:19 PM   #16 (permalink)
smart rear wheel camber
See more info here
tire troubles
Flat Tire Fix MaryG smart Operation and Maintenance 17 01-16-2009 04:24 PM
Tire roar eqwalker smart Wheels & Tires 54 01-05-2009 11:25 AM
One 175-55-16 Tire jonnysan Archive/obsolete (?) threads 4 11-10-2008 11:07 AM
Front tire and rim foyfarlow smart Wheels & Tires 7 10-29-2008 05:26 PM
leather wear retiltxet smart General Discussion 17 09-30-2008 05:07 PM
