Originally Posted by smartacus
Oh come on, the TPMS light WILL NOT illuminate for too much psi. ...
Yes they do - they work by alerting to variations in pressure both positive and negative. I don't know what the exact allowable variations are beyond the set pressure for the smart pressure monitors. Pressure variations before warning differs for different systems but it is usually about 20-30%. The high pressure warning might be a greater variance than the low pressure warning though. You will be notified if the pressures do go too high.
One of the reasons for the high pressure warning is because if you set the pressures too low, then after driving the pressure increase will be more than normal since the tires will be generating more heat. If you do get a high pressure warning then check to see if your cold setting is at the recommended pressures. Also, if you set the pressures correctly but over inflate the tires you will also get a warning.
