Transmission control - Smart Car of America Forums : Smart Car Forum
Old 01-17-2009, 09:28 AM   #1 (permalink)
Ever wondered what makes the transmission do what you want it to? Here it is:
Old 01-17-2009, 01:11 PM   #2 (permalink)
headless's Avatar
Well I read it, but am none the wiser, this is a case for the campaign for simpler english, all I read was blah blah blah blah blah.................
Old 01-17-2009, 01:17 PM   #3 (permalink)
bigcritter's Avatar
It SAID...."When you shift the what'ya'ma'call'it, the do'ma'thingy does what it needs to do to make the thingamawhachit change gears!" Pretty simple!! :>)
Old 01-17-2009, 01:37 PM   #4 (permalink)
JOIN SCOA.YOU'LL BE GLAD
... bigcritter...
If you can't explain it simply, you don't understand it well enough. (Albert Einstein)
...my friend..you're a GENIUS....
jetfuel
Old 01-17-2009, 02:32 PM   #5 (permalink)
24-42's Avatar
NO offense intended: "One person's; "Blah blah" is another's; "Ah hah".
I found the explanation adequate but, for only the shifting via motor operation.
If a doctor explained how a valve in your heart worked, that would not suffice to explain how the heart works.
Donald LaFavor
Old 01-17-2009, 03:23 PM   #6 (permalink)
There's plenty of detail on the actual shifting of the gears to be found in the Technical Guide. I figured this would suffice for most people; my level of interest in this stuff is about the same as for a microwave - just show me the on/off switch.
Old 01-18-2009, 07:07 AM   #7 (permalink)
bigcritter's Avatar
Exactly!! That's ME too! :>)
Old 01-18-2009, 07:58 AM   #8 (permalink)
ME TOO ! Don't tell me how to build a watch, just tell what time it is
Old 01-18-2009, 08:11 AM   #9 (permalink)
I don't understand why my pin won't always engage in the locking groove of the selector drum? It seems at slow speeds my transmission sometimes fails to maintain the selected gear as though it can't make up it's mind to upshift or down shift (in automatic mode). This causes the car to really kick until it can pick the right gear. What's up with that?
Old 01-18-2009, 09:03 AM   #10 (permalink)
Senior Smartie
jonnysan's Avatar
I get that too, sometimes...
I think it is because you go past a certain speed and it shifts up....then you fall below that speed and it shifts back down. I've noticed it when driving out of the driveway at work at speeds below 20...it will shift back and forth between 1st and 2nd until I get to the end, shifting up between speed bumps and then down at the bump.
I've also found that if you are in traffic and think you should be in 5th going downhill at 45mph, it is only in 4th and will not shift into 5th unless you do it manually. That's because it won't go into 5th until you are nearly at 50mph or at least that is the way I have taught my trans to shift.
Transmission oil Bob T Original (450) smart fortwo 19 03-09-2011 07:27 AM
Automated manual transmission control unit jwight smart Operation and Maintenance 14 11-24-2008 08:12 AM
Not sure I can get used to the transmission magnetman smart General Discussion 49 09-03-2008 03:23 PM
transmission charles kitch New Members Area 5 05-28-2008 04:17 PM
Going down... (transmission) gusfraga smart Operation and Maintenance 5 02-10-2008 09:48 PM
