Transmission Fluid for Smart - Smart Car of America Forums : Smart Car Forum
Closed Thread
Old 05-29-2009, 05:31 PM   #1 (permalink)
I will like to know the type of Transmission FLuid I have to use in my Smart For Two?
Marco is offline
Old 05-29-2009, 05:34 PM   #2 (permalink)
From smartUSA's service fluid listing:
"Transmission
Specification (Castrol Manual**) BOT328, 75W-90 API GL4
smart P/N #A 001 989 51 03 10
Mobil Delvac Synthetic gear oil 75W-90
Mobil 1 Synthetic Gear Lube LS 75W-90"
** Full nomenclature from M-B Sheet 235.72 for smart 451 and 454, dated 08 MAY 09.
N.B. smart 450s and 452s use M-B Sheet 235.71, listing Esso ATF D 21065 only (08MAY09).
Old smart is offline
Old 06-03-2009, 01:25 AM   #3 (permalink)
You forgot Amsoil SVG 75W90, too.
Lasts up to 100,000 miles. Best stuff money can buy. I have 3 quarts of it sitting here waiting to put in the smart.
homeslice is offline
Old 06-03-2009, 04:34 AM   #4 (permalink)
I didn't forget it; smart did. If you actually had a smart like many of us here do, you would know that smart doesn't specify any transmission oil change for the life of the car.
Old 06-03-2009, 11:11 AM   #5 (permalink)
What do you mean life of the car? A life of the car for me is about 400,000 miles or more. Actually, there's almost no limit on a new car today. You can easily put 1,000,000 miles on a new car if you take care of it.
Old 06-03-2009, 12:17 PM   #6 (permalink)
It isn't what I mean, it is what smart means, and of which you were informed. Specifically, at no time or mileage does the smart service regimen call for changing transmission oil.
Old 06-03-2009, 12:51 PM   #7 (permalink)
I know a guy who had a '95 Jaguar. He bought 2 large containers of the Amsoil ATF to have it flushed. He went to the Jag dealer and the dealer told him, "You don't need to change it. You have lifetime fluid in there." He then wanted to get a refund on the ATF. I told him, "Are you going to believe those people? There's no oil in the world that lasts a lifetime."
He told me, "Year, you're right. I'll go and flush it."
2 weeks later I spoke to him again and he told me that the car never ran so good for as long as he owned it. I think a year later he ended up becoming an Amsoil dealer himself.
I simply don't trust dealers or mechanics. I read up on the oil and I go the interval the oil states that it's capable of going. I've been doing this for many years and my car runs like new.
On 2 different cars I ran the 0W30 oil and put over 34,000 miles on the same oil in both of them (switching oil filters, of course) and the cars ran flawlessly. I still have one of the cars now. No sludge whatsoever. Zero oil consumption. Gas mileage is still tip top.
Now keep in mind, I am not racing my cars nor am I hauling stuff with them. Also, I do not have any turbo's installed. I was using this car to drive 200 miles per day to go back and forth to work. I lived in a very rural area and had to commute far since there was no other decent paying jobs in my area.
People keep pushing Mobil 1 and other synthetics having no knowledge about them other than what they see in magazines or commercials. It's only fair that somebody stands up for Amsoil. I am saving a fortune with this oil. I just want to see other people saving money with it, too.
Why buy oils that have short intervals? That's a hassle to change them and is a waste of money. I love it when people save money and have their cars run like brand new for as long as they own them. Then if they get 200,000 miles on them, they can continue to keep driving them or if they get bored, they can sell the car. But at least it's their "option" to sell the car. If the car is burning oil and all kinds of stuff, then it makes you want to get rid of it from the problems.
At least a clutch replacement on a fortwo is very reasonable for a German car.
Old 06-03-2009, 01:25 PM   #8 (permalink)
You can not win, Thanks for the specs. Manual transmissions do not have the heat or combustion to deal with so all that I have had never required fluid change just fluid level checks.
Duckhunter is offline
Old 06-03-2009, 01:45 PM   #9 (permalink)
At least the fluid shouldn't be too hard to drain. There's 2 plugs for it. You will need some kind of pump or something to get the fluid to go into the top plug. There's no room to tilt a bottle up in the air to pour the fluid in. I already checked.
Old 06-03-2009, 02:20 PM   #10 (permalink)
Padawan's Avatar
No pump needed, just a small funnel and a short piece of tubing. You can then easily fill from the engine compartment above.
Oh, and make sure you open the top fill plug before you remove the drain plug. If you drain the fluid first and then find that you're unable to open the fill plug, you're in trouble.
Oh, and can you kindly ease up a bit on the Amsoil advertising? There's no question the company makes good lubricants, but they aren't the be-all, end-all. To each, his own. Thanks.
Padawan is offline
Closed Thread
The Smart Transmission-What is the problem? deltadart smart General Discussion 71 03-15-2011 12:43 PM
What this car needs is.... (a windshield washer fluid indicator) jetfuel smart Modifications 45 02-18-2010 11:58 PM
Best transmission (oil) for 451? torqueaholic smart Operation and Maintenance 62 10-25-2009 02:39 PM
Anyone purchased smart transmission fluid? Padawan smart Operation and Maintenance 26 04-04-2009 08:31 PM
auto to smart transmission? kateyk12 New Members Area 7 05-26-2008 03:03 PM
