Movie Game!
Music Game
Old 09-14-2009, 11:08 AM   #1 (permalink)
Drive: 08 smart, 07 jeep
turn signal flasher hyper
this morning, the right hand turn signal behaves in a hyper manner.
turning left, everything is a normal even rate. turning right, the flasher seems to be blinking at a hyper double-speed...fast blinking!
has this happened to anyone else? mine's a 2008 passion.
Last edited by theguywiththelongestname; 09-14-2009 at 06:11 PM.. Reason: misspelling
Old 09-14-2009, 11:11 AM   #2 (permalink)
Padawan's Avatar
Drive: Silver BRABUS Cab "Smoky"
Check your turn signal bulbs (front and rear) to make sure that none of them are burnt out.
Old 09-14-2009, 11:12 AM   #3 (permalink)
will do...thanks for the tip...
Old 09-14-2009, 11:17 AM   #4 (permalink)
Drive: Merlot Red Cabriolet
More specifically, to find out which one is burnt out.
Flashers are designed to turn hyperactive when the load is less than expected. This is why LED lights either need a load resistor (defeating any power savings without reducing reliability) or special flasher relays to work with non-incandescent current levels.
Don't forget the side signal!
John_H is online now   Reply With Quote
Old 09-14-2009, 12:54 PM   #5 (permalink)
thanks for all the insight re: hyper flasher.
it turns out it's the passenger side rear lamp: seems to be a combo brake and turn signal lamp. I found the access panel on the passenger side of the cargo area...but...I think I'll have to poke around all the wires and foam sound deadening to see it there is bulb access through the rear of the tail light lens housing...
...anyone replaced a rear brake/ turn signal bulb? is this a DIY project like on any other vehicle? or will this require Mercedes tech help? will removal of rear body panels be required?
Old 09-14-2009, 12:58 PM   #6 (permalink)
Padawan's Avatar
It's very simple. Just remove the square plastic access panel, move the foam out of the way, and you'll see the black plastic bulb holder. This has clip that you simple bend slightly to release, and the whole bulb holder will pull out.
Old 09-14-2009, 01:05 PM   #7 (permalink)
jefferios's Avatar
Drive: Blue '08 Passion
Has anyone found out out to replace the door's turn signal bulb? Is that an easy task???
Old 09-14-2009, 01:15 PM   #8 (permalink)
thanks Padawan!..I will have to take a peek in that access area when I have some time after work...
Old 09-14-2009, 01:20 PM   #9 (permalink)
I've never actually changed it, only disconnected it when taking off the front. But just changing the bulb (Page 258 in the manual) looks pretty simple.
Old 09-14-2009, 01:21 PM   #10 (permalink)
a2jack's Avatar
Drive: 09 Suzuki SX4 . 08 Smart
BTW the exact replacement bulb is available at Wal-Mart. A2Jack
#13 (permalink)
Smart Enuf
Smart Enuf's Avatar
Sure enough, wifey noticed my left tail light was out today, and my left turn signal was having a seizure. Kragen's -- no luck. Went to Walmart, and what do ya know? Both sets of lights were there (GE Standard series P21/5W for the rear tail/brake, P21W for the reverse light). The P21/5W were available at $2.48 a pair. I decided to buy the reverse lights ($2.98 a pair) at the same time even though I didn't need them yet; no sense making a return trip to Walmart if I can help it.
P21/5W was a perfect fit. Happiness returns...
Smart Enuf is offline Report Post Reply With Quote
turn signal relay Unbeliever Smart Car Operation and Maintenance 4 09-02-2009 01:06 PM
Turn signal flasher problem smartdog Smart Car Operation and Maintenance 5 05-09-2009 11:09 PM
Turn Signal / Flasher Problem lunarx Smart Car Operation and Maintenance 7 09-16-2008 05:38 PM
behind the turn signal bar... letsgoskatepool Smart Car General Discussion 3 06-23-2008 09:53 AM
Faint Turn Signal Sound rrrucke Smart Car Operation and Maintenance 9 03-09-2008 07:49 PM
