Old 10-06-2009, 02:38 PM   #21 (permalink)
gimmie da wheel
ifishcat's Avatar
Drive: suz sv650, and now smart
btw, thanks for this thread, as it so happens, my brake/turn signal need replacing....
good stuff
ifishcat is offline   Reply With Quote
Old 10-06-2009, 03:09 PM   #22 (permalink)
Drive: Cabrio 2008!
Originally Posted by Padawan View Post
Yes, interestingly Walmart is the only store I've been able to locate clear W5W bulbs for the front marker lamps. Most retail auto parts stores seem to have stopped carrying the European bulbs such as P21W, P21/5W, and W5W.
I found P21 and P21/5 at the local PepBoys. I didn't look for the W5W, but they had quite a lineup of lights from GE all together, including those two. I wound up buying an extra set of both. My right blinker needed replacing last month, and the left one needed replacing this week. I figure if they're going to last a couple years each, best to have a couple replacements handy. Plus at $2.50 a set, it's pretty cheep to have on hand.
I did note that the construction on the GE bulbs looked a lot more sturdy than the Phillips bulb I pulled out. The Phillips bulb had flimsy filaments that were held by two crimped tong sets. The GE bulb, on the other hand had very solid coiled filaments, held in by crimped and soldered tong sets. So maybe these will last longer anyway.
Old 02-07-2010, 09:54 AM   #23 (permalink)
My ex has a Yellow and Black 451 and the rear bulb burnt out. I searched this forum and found this post and it was very helpful in finding out how to access the rear bulb area, the bulb part number, and where to find them.
I have a Carquest Auto Parts store close and took the bulb to them. Found another manufacture and part number for the bulb.
Wagner Lighting Products, P/N 17916
It works perfect and is the same brightness as the origional bulb.
Thanks to this forum for all of your help.
Bugsmart
BUGSMART is offline   Reply With Quote
Old 02-07-2010, 10:02 AM   #24 (permalink)
SmartDigger's Avatar
Drive: 09 cabriolet
Bugsmart
Do you know if thyey have an amber bulb for the front
Old 02-07-2010, 11:27 AM   #25 (permalink)
Don't know. Havent had to replace it yet. I'll check, It would be a good idea to check the part number of the bulbs and cross referance them to find out.
turn signal relay Unbeliever Smart Car Operation and Maintenance 4 09-02-2009 01:06 PM
Turn signal flasher problem smartdog Smart Car Operation and Maintenance 5 05-09-2009 11:09 PM
Turn Signal / Flasher Problem lunarx Smart Car Operation and Maintenance 7 09-16-2008 05:38 PM
behind the turn signal bar... letsgoskatepool Smart Car General Discussion 3 06-23-2008 09:53 AM
Faint Turn Signal Sound rrrucke Smart Car Operation and Maintenance 9 03-09-2008 07:49 PM
