UltraSeal a-coming !! - Smart Car of America Forums : Smart Car Forum
Old 08-31-2009, 08:24 PM   #1 (permalink)
Mud Pie's Avatar
After reading all the write-ups regarding UltraSeal, I ordered a gallon, scheduled to be dropped off by the Big Brown Truck tomorrow.
Before I squirt that stuff in my tires, has anyone encountered any problems using it ?
Messed up the tire sensors ?
Threw the tires out of balance ?
Anything ?
Bueller ? Bueller ?
Old 08-31-2009, 10:48 PM   #2 (permalink)
I've run it for about 6 mos. in a 08 smart & an 02 Tiburon... Had slow leaks, caused by new housing area nails. Absolutely sold on it!!! No sensor probs., or balance problems...Getting ready to put it in the 09 smart...Ross
dopco is offline   Reply With Quote
Old 09-06-2009, 06:58 PM   #3 (permalink)
Mud Pie's Avatar
I got an e-mail from UltraSeal saying that their product wouldn't hurt the TPMS sensors, so I squirt the blue stuff in my tires this morning.
Install was extremely easy, for those considering it, watch the DVD that comes with the kit. It has one very necessary tip; a bucket of water and a sponge. You'll need it to clean your rims after you pump the stuff in, the escaping air will spray some out onto your rims (very little) until you get the valve cores back in. No worries though, it's water soluable in the beginning.
They recommend going for a 3-5 mile ride after install to coat the tires.
I didn't notice any ride difference, and I'm glad that I'm now protected in case of punctures. No spare in my smart !!
Old 09-06-2009, 07:05 PM   #4 (permalink)
Been smart for 3.59 years
NCC1701's Avatar
Mud Pie: Thanks for the report. I assumed it would be necessary to jack the car up and deflate the tire to install it. That's not true? In any case, you and dopco are very encouraging.
Old 09-07-2009, 07:37 AM   #5 (permalink)
Mud Pie's Avatar
Nope, no need to deflate the tires.
When you pull the valve core, quickly place your thumb over the valve. Then you put the Ultraseal fitting over the valve, pump in the Ultraseal, pop off the fitting, insert the valve core and you're done.
Naturally, you lose some air, just top it off and you're done.
Old 09-07-2009, 08:43 AM   #6 (permalink)
Kazuano's Avatar
Off topic but...will this work in a bicycle tire with a tube?
Kazuano is offline   Reply With Quote
Old 09-07-2009, 08:50 AM   #7 (permalink)
Mud Pie's Avatar
Yep, it'll work on any tire. Car/truck/motorcycle/bike. Tube or tubeless. It comes with a spec sheet with all tire sizes.
Old 09-08-2009, 08:22 AM   #8 (permalink)
psimison's Avatar
ultraseal
Does pulling the valve core mess up the sensors?
psimison is offline   Reply With Quote
Old 09-08-2009, 11:17 AM   #9 (permalink)
No....
Old 09-10-2009, 07:45 AM   #10 (permalink)
Where did you get yours? How much was it? How many tires will a gallon do? Are you using the "commercial" or the "bulletproof" ?
wildman is offline   Reply With Quote
Pre-Flat Sealant, Ultraseal, Not Interfering with Sensors rgaus smart General Discussion 27 06-27-2009 03:52 PM
New mpg requirements coming Smartdavis The Car Lounge 21 01-27-2009 11:35 AM
Orphan coming in soon- Drewid New Hampshire Chapter 0 12-09-2008 10:36 AM
Ultraseal-Anyone have experience with it? kwagar smart Operation and Maintenance 4 10-14-2008 05:44 PM
It's coming faith in dc Mid-Atlantic Region 7 07-30-2008 01:41 PM
