Wheezy heater? - Smart Car of America Forums : Smart Car Forum
Old 12-09-2008, 09:41 PM   #1 (permalink)
Wheezy heater?
Now that the weather here in Illinois is cold enough to turn my heat up to max, the blower at all speeds makes a wheezing noise but starts to go away when I turn the temp down below 70 and completely gone at coldest setting at all speeds. Anyone else have this problem?
Thanks,
Andy
Andrewlcox is offline   Reply With Quote
Old 12-10-2008, 11:29 AM   #2 (permalink)
Padawan's Avatar
My guess would be that the sound you're hearing is coolant flowing through the heater core.
Old 12-10-2008, 12:42 PM   #3 (permalink)
It is the sound of air. I need to check the duct for an obstruction.
Andy
Old 12-10-2008, 05:55 PM   #4 (permalink)
Not Selling on Ebay
When the blower is running, open and close the dash vents. The vents close completely when you push the sliders toward the outside of the car, passenger side goes extreme right, driver side extreme left. I sometime get strange air noise if the vents are completely closed and the positioning dial is not set to floor only.
Old 12-10-2008, 07:07 PM   #5 (permalink)
SmartDigger's Avatar
would take it is to the dealer. Let them find out what it is. sounds like something in the before or in the exchanger box since you can not hear it when the damper to the heater core is closed. pull your filter out and see if it still makes the noise.
Having intermittent problem with heater blower Harleyduo smart Operation and Maintenance 136 01-28-2012 01:33 PM
Smarter for us. - heater in Nebraska winters? frankie47 New Members Area 10 11-26-2008 10:16 PM
Block heater? scdaf smart Operation and Maintenance 17 10-24-2008 02:38 PM
Heater temperature control, not so hot. erikdfier smart Operation and Maintenance 14 04-10-2008 06:54 AM
Does it have a heater? bob/cathy smart General Discussion 6 01-19-2008 03:27 PM
