HOME FORUMS GALLERY CLUBS
Music Game
Old 11-20-2008, 06:15 AM   #1 (permalink)
Drive: Dodge Ram, Honda Del Sol
Whistle sounds when AC or Heat is on
I have noticed a whistle and it seems to be getting worse. Anyone else have this issue. I am going to contact the dealer as it is annoying to say the least. it seems to be worse when I have the system on the feet setting.
Dink
dink74 is offline   Reply With Quote
Old 11-20-2008, 06:51 AM   #2 (permalink)
JOIN SCOA..YOU'LL BE GLAD
Drive: modified 65 stang conv
..sounds like a vent obstruction...does it change pitch with a change of fan speed?
jetfuel
Old 11-20-2008, 07:23 AM   #3 (permalink)
You can definitely hear the air flowing through mine, at least on settings above 1. I wouldn't call it a "whistle" but it's definitely an air flow sound of some sort. I just assumed it was because the Smart was forcing a relatively large volume of air thru a relatively small duct system. I'll be interested in what your dealer has to say.
Old 11-20-2008, 08:43 AM   #4 (permalink)
..what does it do when you set it for recirculation?
jetfuel
Old 11-20-2008, 09:03 AM   #5 (permalink)
What end goes in there?
Drive: Methane Powered Smart
Turn up the radio
Thats what I do
Old 11-20-2008, 09:29 AM   #6 (permalink)
jetfuel
Old 11-20-2008, 09:46 AM   #7 (permalink)
Drive: Cabrio 2008!
I have the same issue if the heat selector isn't all the way open or all the way closed sometimes. I also get a whine out of the antenna if the window is down, and from the vents if they're all closed.
Old 11-20-2008, 08:06 PM   #8 (permalink)
Mine sounds the same with and without the recirculation. It seems to be blower speed dependent - definitely noticeable but not annoying. (With or without the radio on!)
Old 11-20-2008, 08:10 PM   #9 (permalink)
smartYsmileS's Avatar
~ Mine whistles also, only when set to 2 or above . . . I've only used the heat so far so idk if the same is true of the AC . . .
smartYsmileS is offline   Reply With Quote
Old 11-21-2008, 04:17 AM   #10 (permalink)
Ours only does it when we have the heat on. I played with it some last night and found if I run the heat on highest setting for a few minutes and than change from hot to cold it stops when I go back to hot so it looks like the flap to seal off the hot from cold is not sealing properly when cold. May go away with time depending on how hard the seal is from the factory.
Dink
Forum Jump
Radio 9 Stations Sounds Slightly Off Freq spanky10 Smart Car Operation and Maintenance 7 09-21-2008 10:56 PM
Sounds like a scam! dagwodzz Smart Car Delivery 9 08-22-2008 08:52 PM
Stubby Antenna Whistle gryphon Interior & Exterior 14 08-13-2008 08:41 PM
Sounds like we're getting closer! mikie Smart Car News & Rumors 2 12-07-2007 06:29 AM
Smart Whistle-Stops U.S. Tour SMART Smart Car News & Rumors 0 06-21-2007 10:13 PM
